LED Conversion Tips Needed - Page 3 - JeepForum.com
post #31 of 110 Old 01-24-2011, 10:46 AM
chriskeenan
Originally Posted by trevsbmw View Post
I wasn't aware their was blue tape. I will look into this but I went with the blue lights instead of the red. Maybe I wont need to remove the tape. What did you end up doing for your dome light? I might send this PCB back.
If the LED's behind it are blue then don't bother to remove the tint strip but any other color i would recommend it.
My dome light I did with a G4b-xHP10-d from superbright, its ~10$ cheaper than the universal dome kit they sell, it looks like this.
It just sits inside on the lens, the connections to the dome light base need to be done better. I'm eventually going to put two of these in there and angle them outwards some, that's why there's no permanent mounting yet.
chriskeenan is offline
post #32 of 110 Old 01-24-2011, 11:45 AM
Shanker67
and i guess the foglight switch takes a neo4 and a neo3 as well? cause that one has the indicator too
Shanker67 is offline
post #33 of 110 Old 01-24-2011, 11:48 AM Thread Starter
trevsbmw
I dont have a fog switch but if it follows suit it will have both yes.
1999 2 Door Cherokee SE w/ 4.0L I-6. Automatic. APN Header, Hooker Aero Chamber Muffler. Hella H4 Euro Headlights w/ Hella Xenon Bulbs, Eautoworks.com wiring harness, Heated Seats
trevsbmw is offline
post #34 of 110 Old 01-24-2011, 12:05 PM
Shanker67
alright sounds good, i'd like for all the middle ones to glow red but i dont know what kind of snags ill run into
post #35 of 110 Old 01-24-2011, 03:04 PM Thread Starter
trevsbmw
Chris what do you thing about running white LED's in the HVAC?
trevsbmw is offline
post #36 of 110 Old 01-24-2011, 03:17 PM
Shanker67
just ordered 5 of the 74-xHP3, to do my instrument cluster with, we'll see how it goes
post #37 of 110 Old 01-24-2011, 03:26 PM
chriskeenan
You'll get about the stock colors, but brighter, and more "crisp" looking. The HVAC overlay has the tinting and the stock bulbs give off a dull yellowish light, the red areas will still be red but a bit lighter in color, the old blue-green areas will be a light blue color.
If you want a better idea of how it will look pull the HVAC controls out and put a led flash light up against the holes for the old bulbs (with the bulbs removed obviously), it should give you a good idea of what they will look like.
White LED's are the only LED's that give off all the colors, for example a red LED usually gives of light at ~630nm wavelength and no light at any other wavelength so it will only shine through red filters. so if you stick a blue filter in front of a red LED it will filter out all wavelengths that are not blue. White LED put off all colors but are not very efficient at producing one through a filter. Now if you put a 4000mcd white LED through a blue filter it filters out the red and green produced by the LED leaving you with ~1/3 of the LED's total light output (~1330mcd).
post #38 of 110 Old 01-24-2011, 03:33 PM Thread Starter
trevsbmw
You'll be very happy with those. What color did you go with? Just remember that the 74's are polarized so it might take a few times of pulling the cluster in and out till they all light up. It took me 6 times because I wasn't getting good contact.
I just remembered something else that I had to do when I installed the 74's. The 74 bulb doesn't fit very snug into the illumination sockets that are in the cluster. I had my old dummy light cluster laying around and I used some of the other light sockets like the ones from the blinkers, check engine light etc. to install the 74's tightly. Maybe Chris can chime in on this. The Illumination sockets just seem to be a touch bigger than the rest of the sockets.
Shanker if you want to PM me I can send you 5 of the sockets you need if you pick up shipping.
trevsbmw is offline
post #39 of 110 Old 01-24-2011, 03:43 PM
Mark-96-XJ
What bulbs for the hvac controls?
1999 XJ Classic, Auto, Power everything, 3 inch, GY Wrangler Radial 31's
1996 XJ 5 Speed, 100% Herculined, Rough country 4.5, BFG A/T 33's
2012 Honda Ruckus, Stock for now, 114 MPG, Daily Rider
Mark-96-XJ is offline
post #40 of 110 Old 01-24-2011, 03:52 PM Thread Starter
trevsbmw
Neo4's you need two of them
trevsbmw is offline
post #41 of 110 Old 01-24-2011, 03:53 PM
Shanker67
i went with blue, oh they didn't fit in good inside the stock sockets? that's weird, what kind of cluster do you have? sport? classic? SE?
post #42 of 110 Old 01-24-2011, 03:55 PM Thread Starter
trevsbmw
Mark who is that babe? Is that your sister?
trevsbmw is offline
post #43 of 110 Old 01-24-2011, 03:59 PM Thread Starter
trevsbmw
When I bought the Jeep I had an SE cluster. One of the first things I did was switch to a sport cluster. When I got the LED's in the mail the other day I went into my garage and grabbed my SE cluster so I could install the LED's and have everything ready to go when I pulled my dash apart. This is where I noticed the Illumination sockets hold a little bit larger bulb then the other sockets. So I just used 5 sockets from other gauges and made it work with that.
trevsbmw is offline
post #44 of 110 Old 01-24-2011, 04:28 PM
chriskeenan
I had one that didn't fit snug and was getting bad contact, I just bent the contact in a little with a small screwdriver, it works fine to this day. I don't know about the differences between the sockets aside from the different colors.
post #45 of 110 Old 01-24-2011, 04:35 PM
chriskeenan
I've got no idea what the 96 HVAC bulbs are, they might not be neo4's, it wouldn't hurt to pull the unit and check before you order them.
pinoin seal and bearing tips needed srhcherokee24 XJ Cherokee Technical Forum 25 02-09-2010 05:35 PM
4WD conversion info needed Sdenzik XJ Cherokee Technical Forum 1 01-21-2010 12:05 AM
Parts needed for composite rotor conversion on a 99 nexus42i XJ Cherokee Technical Forum 0 01-25-2009 07:48 PM
Info needed on abs- to non- abs conversion etc.. Timo_90xj XJ Cherokee Technical Forum 5 06-25-2006 01:35 AM
Tips for closed radiator conversion... cyberbackpacker XJ Cherokee Technical Forum 1 08-26-2004 03:46 PM
