Quantcast leaky injector - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > leaky injector
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 09-29-2004, 11:03 PM   #1
Rasta Monsta
1990 XJ Cherokee
leaky injector
anybody ever seen a fuel injector actually leaking externally?
also, what type of lube (if any) would you use to ease reassembly of fuel rail to injectors? i was thinking about a touch of silicone assembly lube. . .
rasta
[B]Thunder the Grey[/B] - 1988 Laredo 4.0, beloved beater, 2WD
[B]Thunder the White[/B] - 1990 Limited 4.0, super cherry, all options
Rasta Monsta is offline   Reply With Quote
Old 09-29-2004, 11:12 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
A little motor oil will work.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 10-05-2004, 01:13 PM   #3
Rasta Monsta
1990 XJ Cherokee
Little help here? Has anybody seen a fuel injector leaking externally? I am trying to isolate the leak, and it is a biotch. Already replaced the seals. . .
rasta
Old 10-05-2004, 08:57 PM   #4
bigjeep913
yeah i had the same problem on my other cherokee, i thought it was just the o-rings so replaced them all but it was leaking around where the top plastic part meets the body of the injector. i dont know if it is in the same area as yours but i think that when they start leaking like that then there is nothing to do but replace them, if anyone knows otherwise correct me. hope that helps ya.
bigjeep913 is offline   Reply With Quote
Old 10-05-2004, 09:02 PM   #5
Rasta Monsta
1990 XJ Cherokee
yeah, so did you replace the leaky one? did it work?
thanks for the reply!
rasta
Old 10-06-2004, 10:47 AM   #6
bigjeep913
yeah i replaced it and all the other ones that were leaking. i think four of them all started leaking around the same time, which wasnt fun replacing. anyways, good luck.
Old 10-06-2004, 12:43 PM   #7
XJ in LA
bought 6 for $125ish from this guy
a couple years ago and no problems.
http://www.fiveomotorsport.com/Injector_SetsJEEP.asp
XJ in LA is offline   Reply With Quote
Glock Forum
