Leaking power steering reservoir, replace pump or upgrade reservoir? - JeepForum.com
post #1 of 3 Old 08-26-2013, 03:52 PM Thread Starter
Agility
1997 XJ Cherokee
Should I replace the power steering pump while I've got it off or spend that money on an aluminum reservoir from PCS?
http://www.pscmotorsports.com/vehicl...reservoir.html
EDIT: added picture of aluminum reservoir
Agility is offline
post #2 of 3 Old 08-26-2013, 06:00 PM
Mud Pilot
If there's nothing wrong with the pump itself then I would spend the extra money on the upgrade. Plus with the upgrade you will never have to worry about it cracking again.
Although I have never heard of one cracking in the first place.
Mud Pilot is offline
post #3 of 3 Old 08-26-2013, 06:12 PM Thread Starter
Agility
1997 XJ Cherokee
Mine seeps fluid from around the plastic fitting for the return line. I wouldn't so much be worried about the reservoir cracking as the same sort of plastic fitting failing again.
I haven't had a power steering pump problem yet and threads on power steering pumps aren't super common here. Makes me inclined to go with the aluminum reservoir.
Agility is offline
