Leaking front axle seal, can I drive a thousand miles tomorrow? - JeepForum.com
post #1 of 10 Old 08-22-2012, 06:53 PM Thread Starter
bend
Hi,
I did some work on my Jeep two weeks ago, and had the front axles out.
Two days ago, I noticed some oil leaking from the front left axle, dripping onto the tire. Not enough to reach the ground. I saw the vent tube was really kinked right at the differential, so I hoped that was the problem, and not that I had a bad seal as a consequence of removing and replacing the axle. I straightened the vent hose. The differential was still very full of oil.
I drove another 15 miles that evening, and there was either no leakage, or just a drop or two on the end of the axle housing.
The next morning, I dried the axle completely. I made another two 25 mile drives, no leakage. Problem solved!
Today, after another two 15 mile drives, some more leakage, and dripping onto the tire.
Any suggestions as to whether this is something that will continue to leak very slowly? In which case I can leave tomorrow and drive 1000 miles over the next two days. I could also check the level and refill if needed after 500 miles. But if it is something that might get catastrophically worse, then I need to stay where I am (would mean missing work) and fix the problem before I leave.
One note - it may have been leaking before I removed and replaced the axle, and I didn't notice. It was only because I was giving the front end a careful look-see that I noticed this leak.
Any experiences?
bend is offline
post #2 of 10 Old 08-22-2012, 07:11 PM
ROTTEN
You answered your own question. Keep checking the level. Keep it clean. Yes it can get worse but maybe not. I put 2 in my old xj
If anything it would just leak more.
Its an easy job. Maybe half an hour with the right tools. Make sure to clean the sealing surface good or it will happen again.... that's why I did it twice...
ROTTEN is offline
post #3 of 10 Old 08-22-2012, 07:16 PM
BriansCJ
1994 XJ Cherokee
I would check the level and bring some fluid with you.
As you describe it, I wouldnt lose sleep over it or miss the trip.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #4 of 10 Old 08-22-2012, 07:54 PM Thread Starter
bend
Which tools? The write-up I've seen referred to is here:
http://www.stu-offroad.com/axle/d30seals/seal-1.htm
which makes it seem like a longer job, and you need an assortment of sizes of pipe, etc. More like a 4-6 hour afternoon job.
bend is offline
post #5 of 10 Old 08-22-2012, 07:56 PM
donthelegend
x2 Just keep an eye on it and have extra fluid. I put probably 5000+ miles on mine with a leaking axle seal almost the exact way you describe, sometimes there would be oil on the tire, sometimes not, and when I checked the fluid, it was still almost full.
donthelegend is offline
post #6 of 10 Old 08-23-2012, 05:48 AM
wgirvine
1992 XJ Cherokee
Its an easy job. Maybe half an hour with the right tools...
So you jacked up the front of your Jeep, removed the wheels, removed both front axles, removed the diff cover plate, removed the differential, replaced both seals, put the diff back in, the cover back on, the axles back in, refilled the axle with lube, put the wheels back on and down-jacked your Jeep... all in 30 minutes?
Dang, there's a NASCAR pit crew that needs you.
Or perhaps you were thinking of the REAR axle seals...
The road goes on forever, the party never ends....
wgirvine is offline
post #7 of 10 Old 08-23-2012, 06:33 AM Thread Starter
bend
Thank you for your responses, I'll be off on my trip today.
bend is offline
post #8 of 10 Old 08-23-2012, 07:51 AM
Millermagic
Mine is leaking at the pinion seals. I just have to keep them topped off.
Don't look at it like it's leaking, look at it as it is self flushing!
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #9 of 10 Old 05-06-2013, 04:17 PM
SpideYJeep
Can you really get the rear diff-axle seals done in 30mins?
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #10 of 10 Old 05-06-2013, 04:28 PM
ROTTEN
This guy is an idiot....^^
And needs to learn how to read.
I was referring to my pinion seal. Sorry
Punches self in forehead
I'm new
ROTTEN is offline
axle seal , differential , front axle , leak
Leaking front axle on the driver side seal Captainofiron XJ Cherokee Technical Forum 15 03-03-2014 09:40 PM
Leaking axle tube seal Highway 4x4 XJ Cherokee Technical Forum 0 05-24-2009 12:16 AM
Front Axle Seal Leaking.. 2@Wolffway XJ Cherokee Technical Forum 1 03-19-2008 11:41 AM
Original ALTERNATOR, 194 thousand miles. 4.0H.O.XJ XJ Cherokee Technical Forum 10 07-27-2007 06:26 AM
Front axle leaking... bad seal? NotMatt XJ Cherokee Technical Forum 2 04-22-2004 08:57 PM
