leak at fuel rail coupling - JeepForum.com
post #1 of 2 Old 10-13-2009, 06:18 PM Thread Starter
beater_xj
My fuel line is leaking where it attches to the fuel rail. I had it apart a few times recently and I really destroyed the inner steel clip that hold sthe line on the rail. Will getting a new inner clip fix the leak or do I need seals as well? Any place other then dealer to get the clip?
It was not leaking before I took it apart.
05' Rubicon 6spd - 4" Saavy w/ Bilstein, 35" MTR
08' BMW 335i 6spd - JB4, FBO, E40 12.39@115.5
beater_xj is offline
post #2 of 2 Old 10-13-2009, 06:37 PM
Paradise XJ
1988 MJ Comanche
You're supposed to replace the o-rings whenever you take it off. Get a new disconnect insert with the o-rings and spacer. NAPA maybe, might have to get the kit from the dealer.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Ę
Paradise XJ is offline
no pressure in fuel rail. fuel pump went? sega2010 XJ Cherokee Technical Forum 2 02-06-2010 06:08 PM
fuel rail leak barrelbronco XJ Cherokee Technical Forum 7 09-17-2009 04:42 PM
No fuel pressure at rail. What else besides the fuel pump could it be? Element96x XJ Cherokee Technical Forum 14 03-28-2009 08:35 PM
fuel injector/fuel rail question LeeBee XJ Cherokee Technical Forum 4 11-16-2007 12:02 PM
Fuel Line/Connection to Fuel Rail jedwards XJ Cherokee Technical Forum 2 11-04-2004 02:13 PM
