Quantcast Leaf Springs v.s. Coil Springs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Leaf Springs v.s. Coil Springs
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 03-19-2008, 11:08 AM   #1
JMC-14
Just for my information, what is the advantages of having leaf springs versus coil springs. I'm guessing one of the big cons of leaf springs would be the stiff bumpy ride. Which would make for a better setup in the off-road community?
JMC-14 is offline   Reply With Quote
Old 03-19-2008, 11:31 AM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Depends on what you are wheeling. Mud and leaf spring go pretty well together. Rock krawling and coils go well.
It all boils down to the design of the lift to get the max effecientcy out of the coils or leafs. Hands down the best set up in the offroad community are niether. Coil overs are a much better solution to the suspension equation.
I like the XJ coils front and leaf rear for the simple matter of stability. Get some flexy enough leaf springs and you should have no issues making the suspension travel as you desire.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 03-19-2008, 11:33 AM   #3
jeepnphreak
1989 XJ Cherokee
Leaf springs have the benifits of striegth and symplicity, there really easy to fix on the trail. a little wire and tape and you limp out of a leaf. Coils have very litter stability in holding the axle in place, is you losse a control arm than you axle is catiwampus.
Cons. are defanly the stiff ride. Very little flex when comapred to coils.
For the off road ability, it depends on what you are doing. For mud bogging and flatter terrain leafs are great.
for rock crawling where massive flex is needed than coils are unbeatable.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline   Reply With Quote
Glock Forum
