which leaf springs should I get - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > which leaf springs should I get
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectJKS Now Available at www.baseline4x4.com, Trackbars, SkidsFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 02-09-2014, 07:35 PM   #1
71nova
1994 XJ Cherokee
I need new leaf springs on my jeep, the rear sits way low. When I stomp the gas and drop the clutch the *** end bounces off the tires(scary), I only did that once btw. Anyway I measured the distance between the axle and frame before and found I had a 6 inch lift, I run 35's and have cut out fenders. but the rear leafs are beyond flat, I am wondering if I should just get 6" HD leafs or if its lifted by shackles(I put revolvers on the back). the weird thing to me is that it seems that I have stock brake lines, they certainly wont allow my revolver shackles to fully turn out, different thing though. How can I tell what and what size I need without buying fifty different options or wasting the local 4x4 shops time by asking them?
71nova is offline   Reply With Quote
