Leaf Springs and Shackles - JeepForum.com
post #1 of 5 Old 03-28-2012, 10:36 AM Thread Starter
ivtaku7
I came across a post a few days ago about someone doing a 4.5" lift set up, but choosing to go with 3" or 3.5" leafs in the back with a 1" or 1.5" shackle.
For my upcoming build I want to go with a 4.5" lift, but I'm not clear on what the shorter leafs with the shackle will do for you. Does a set up like this give you more flex in your suspension or would you be better off going with a 4.5" lift with the proper 4.5" leafs?
ivtaku7 is offline
post #2 of 5 Old 03-28-2012, 10:50 PM Thread Starter
ivtaku7
bump
ivtaku7 is offline
post #3 of 5 Old 03-28-2012, 10:57 PM
the_weirdo
the_weirdo's Avatar
In general, ,you should get better flex with a 1" shackle and 3.5" leafs. Leafs are arched more to get more lift. Arching springs more tends to make them stiffer. Stiffer springs tend to flex less.
the_weirdo is offline
post #4 of 5 Old 03-28-2012, 11:05 PM
chiefbill1959
I have looked around and I think it helps with ride quality. I do know that as you go higher your ride quality somtimes suffers. It also helps in your flex too. Many aftermarket shackles have zerk fittings so you can grease them. This would also help maintaining your ride quality.
96 XJ, 3 in. Rustys full pack lift, 4.0, AW4, D35, C8.25
86 XJ, 3 in. RC, bb rear pack, 3.4 L engine
chiefbill1959 is offline
post #5 of 5 Old 03-29-2012, 08:02 AM Thread Starter
ivtaku7
Perfect, this is exactly what I needed to know, thanks guys.
ivtaku7 is offline
leaf springs , shackles , susepnsion lift
How quickly will longer shackles prematurely compress leaf springs? andrewmacc XJ Cherokee Technical Forum 6 12-02-2010 03:50 AM
Add-a-Leaf Vs. Shackles jeepjack1995 XJ Cherokee Technical Forum 4 09-09-2010 10:56 PM
Leaf doesn't fit. Do I need shackles? suv1186 XJ Cherokee Technical Forum 5 04-06-2009 10:37 AM
Shackles help with Leaf Sag jeepnatv4life XJ Cherokee Technical Forum 6 12-03-2008 01:25 AM
RE 4.5 Leaf Springs/ Stock Shackles TreddyoXJ XJ Cherokee Technical Forum 14 06-13-2008 06:26 PM
