Leaf spring problem - JeepForum.com
post #1 of 3 Old 07-29-2013, 10:39 PM Thread Starter
xj_Chris
Leaf spring problem
My bolt snapped with it still in the metal sleeve of my bushin and still in the theeads would it work if i cut the bolt on both sides and removed the spring an then use a drill bit an drill into it and then get a left handed drill bit and back it out please let me know! Gotta get this done really quick
xj_Chris is offline
post #2 of 3 Old 07-29-2013, 10:48 PM
kaitlynsdad
my yj springs did the same thing i just cut it flush with the side of the spring and start out drilling thru it with a small bit and gradually go up till it gets thin enough to get out and the ones you put back in put never seize on them it want happen again
kaitlynsdad is offline
post #3 of 3 Old 07-30-2013, 05:25 AM
Azzy
The factory loctites them. you need to apply heat, and a good bit of it to remove them. Hopefully that saves you on the other side.
For future removals, if the leafs are going, use a dremel or air grinder to cut the sleve around the bolt, and take it out that way. After you hit it with a torch.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
