#1 | |
leaf spring hardware
I'm at work and can't call around so I turn to the all mighty jf. Leaf srping hardware. Centering pin, bracket and all that good stuff. Can that picked up at a local parts store or is that dealer specific? Also I'm replacing my shacles anyone know what size the bolts are so I can replace them.
#2 |
Not sure what you mean by bracket. but center Pins, ubolts and spring clamps are available at any auto parts store.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /..... 93 VT1100 - Harley killer. 97 ZJ 4.0 / 242 / Stock 93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten. If it aint dirty, it aint a JEEP, it's just a SUV. |
#3 |
Yea sorry about that I was in a hurry but that's what I was lookin for. Thanks man.
#4 |
Shackle bolts are : M14x2.0x120 - top and bottom.
Keep in mind you will also need 14mm washers; and also 14mm x 2.0 nuts for the lower bolts (preferably nylock nuts)
1992 YJ -2.5 Old Man Emu lift, RC 1-1/4" Boom greasable shackles, JKS Discos, 1" Daystar BL, 33x12.5x15 BFG AT KO's mounted on 15x8 Cragar soft 8's, flush mounted tailights, SJFab front bumper, TKH Fab swingout tire carrier welded to a Dirtworx rear bumper, Tuffy stereo console, RC SS Extended brake lines, Home brew plate relocation bracket, Magnaflow Cat, Dynomax Cat back, No track bars front or rear 1997 XJ - 4.5 RC coils + extra OEM spring isolator(6.5" actual front), OME medium duty springs+OME extra leaf + Teraflex 1.5 shackles (6.5" actual in rear), OME Long travel shocks, OME SS, IRO Adj TB, IRO Adj LCA'S, IRO Adj Uppers, RC Control arm drop brackets, JKS Quicker Discos, SYE / XJ shaft, 33x12.5x15 BFG AT KO's on 15x8 Cragar soft 8's, RC SS extended Brake lines, Hella 500's 1996 ZJ - RE 2 inch BB w/shocks (rides like crap), OME SS, 31x10.5x15 General Grabber AT2's - SOLD |
#5 |
just go to a fastener specialty store when you need those bolts you can get them cheap!!
#6 |
i called around to a few auto parts stores, advanced and pep boys, neither one had anything in stock.
#7 |
axle shim
i need to change the angle of my dirveshaft by shiming the axle. where should i look for these.
#8 |
anyone? before i order them of the interweb.
#9 |
IRON ROCK OFF ROAD should be able to set you up with everything you need.
#10 |
actually i ordered some stuff from them thursday or friday and forgot to add it on. i figured i could get it locally so i didnt worry about it. just got off the phone with them and added everything on to my order with no problems. so far great people to deal with over there and no complaints from me so far.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
