Leaf Spring Alignment with Shackle '97XJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Leaf Spring Alignment with Shackle '97XJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 09-16-2014, 03:18 PM   #1
Jennpenn
1997 XJ Cherokee
I had a lot of creaking sounds coming from the rear of my ’97 XJ. It turned out the shackle on the leaf spring over the tailpipe had completely deteriorated. I got an OEM replacement and installed it this weekend. Of course I encountered just about every nuisance problem covered on every thread but I managed to come up with a new one. When I raised the spring back into position, the eye didn’t line up with the shackle – as you can see by the photo it is off by about 1”. Is there a trick to this? Is it as simple as loosening the U-bolts and knocking the spring over or is there more to it than that and; is this the sign of a larger problem? This was supposed to be the easy part.
Jennpenn is offline   Reply With Quote Quick reply to this message
Unread 09-16-2014, 04:54 PM   #2
jersey_jim
1994 XJ Cherokee
What I usually do for this I use a ratchet strap, grab the far side of my hitch and the other hook on the leaf spring and just ratchet it into place with the ubolts a little loose.
I used this method a few weeks back when replacing my leaf spring bushings snd to realign my front axle when doing my control arm bushings
I hope this helps
94 xj - 5.5" rubucon express long arm, 4.56's, shafted & Detroit locked on 35's
jersey_jim is offline   Reply With Quote Quick reply to this message
Unread 09-17-2014, 05:53 AM   #3
Jennpenn
1997 XJ Cherokee
Thanks JJ. I gave it a halfass attempt last night. I couldn't quite get the angle right with the gas tank in the way so the strap it was just pulling the spring down. But I can see how that would work so I'll give it a go this weekend. Thanks for the help
