LCA installation - JeepForum.com
post #1 of 10 Old 11-22-2005, 03:51 PM Thread Starter
4x4life
LCA installation
Ive just purchased 4.5" Fixed LCA's, i plan to throw these on there when i nstall my 2" spacers, how do i got about the installation of them? Also if im installing the Spacers at the same time, do i need a spring compressor? or will the axle droop enough for me to get them in there?
90 Cherokee XJ - Flat Black - 4.0 - aw4 - np242 - Around 6" of lift (3" springs 3" blocks 2.5"spacers 3"AAL) Rough country - 31x10.5" coursers - Some lights - Custom bumper-Class 5 rear hitch- Flowmaster 40 exhaust - k&N intake- Surco safari rack
Originally Posted by tealcherokee
if i wanted a hummer, id call your sister:dunno:
4x4life is offline
post #2 of 10 Old 11-22-2005, 03:56 PM
beckXJ
If you have as much flex as badger you shouldn't have a problem dropping a spring...
I envy his rig.
1998 Cherokee Sport
Dynomax Cat-back and Magnaflow Cat
Pioneer Premier DEH-P880PRS
Image Dynamics 12" IDQ's
2" BB with 30"s and more on the way
beckXJ is offline
post #3 of 10 Old 11-22-2005, 05:52 PM
meat12
meat12's Avatar
If you are replacing LCA's during coil spacer install, you should not have any problem as you should have plenty of axle droop. If you do get a compressor, make sure it is a strut compressor not a spring compressor.
91XJ- NP231, 31x10.5 MTR's, 15x8 soft 8's, BB, K&N intake, Cherry bomb exaust, CB, Stereo mods, fog lights, custom Aluminum body work to cover rust.
Rember: If they dont find you handsome, at least they will find you handy!
meat12 is offline
post #4 of 10 Old 11-22-2005, 06:35 PM Thread Starter
4x4life
Any imparticular advice as to geting the stock arms off? are they difficult to get off? when i unbolt them will the axle fall and if so, should i jack it up?
4x4life is offline
post #5 of 10 Old 11-22-2005, 06:55 PM
beckXJ
You'll want to have support underneath it. Also, spray the crap outta those bolts and stuff with some PB Blaster in the few days before the process. Good luck with the install.
1998 Cherokee Sport
beckXJ is offline
post #6 of 10 Old 11-22-2005, 07:00 PM
xj89
i just repalced mine, and added a spacer. jack up the jeep, place jack stands underneath, and dont completly lett he axle droop but just about..remove the arms from the axle, and disconect the track bar and sway bar and ur axle will droop enough to not need spring compressors. then chuck on the spacer put the coils back in place push the axle forward. put on the arms. and u should be good to go. o yea dont forget to disconnect your shock on the axle mount. u dont want the weight of the axle hurting them if u leave them connected.
74 CJ5
86 CJ7
89 Cherokee
xj89 is offline
post #7 of 10 Old 11-22-2005, 08:49 PM
Brandon11130
somtimes they come off easy somtimes not, my driver side came off no problem, but the passenger one i had to sawzall off the bolt, its still stuck inside the stock lcs that thing is not comming out.
1959 JEEP CJ5
We do not ask for your poor or your hungry. We do not want your tired and sick. It is your corrupt we claim. It is your evil that will be saught by us. With every breath we shall hunt them down. Each day we will spill their blood ‘til it rains down from the skies.
Brandon11130 is offline
post #8 of 10 Old 11-23-2005, 09:19 AM Thread Starter
4x4life
And you didnt have to touch the upper arms?
So, correct me if im wrong, but your at 5.5" and you did not need new UCA's? Becasue im really hoping that im not gonna need Uppers.
4x4life is offline
post #9 of 10 Old 11-23-2005, 10:07 AM
fryed_1
"should have" and "need" are big differences.
Yes, you should get new UCA if you're going 5"...
No, you don't need them...
You will probably get less vibes with new UCA as they will help to correct the front pinion angle. When you put the longer LCA on, it will point your pinion more towards the ground than before, but not enough to do any real damage, other than prematurely wearing out ujoints.
'94 XJ - 8" Long arms, 9" rear, 35's
'89 Waggy
'48 Willys
fryed_1 is offline
post #10 of 10 Old 11-23-2005, 03:05 PM
xj89
i need to fix my sig...im at 4 inches. i replaced the uppers and lowers...but this thread was only discussing the lowers. i dont have the money for a while to go to 5.5
i would get yourself a set of uppers as well, i just re read ur orignal thread the short upper arms are gonna pull the axle upwards, and make the driveline angle really off. i dont see things going to well if u leave the uppers stock.
74 CJ5
86 CJ7
89 Cherokee
xj89 is offline
4.10 installation Nelg7654 XJ Cherokee Technical Forum 1 04-29-2009 08:38 PM
PCM Installation??? wangtyme XJ Cherokee Technical Forum 1 09-08-2007 09:58 AM
amp installation crazyxj01 XJ Cherokee Technical Forum 4 08-25-2005 03:42 PM
installation VTJeep11 XJ Cherokee Technical Forum 4 07-28-2004 05:17 PM
A-a-l Installation ??? rocknerd XJ Cherokee Technical Forum 6 06-18-2004 08:14 AM
