Quantcast last lift question from me - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > last lift question from me
Old 06-03-2005, 12:37 AM   #1
TheRyans33
**** it, lets do it
TheRyans33's Avatar
1979 CJ7
ok so i have been doing an assload of research and how about this...if i get the RE 4.5" with the cv driveshaft, sye and lets say 31's, will i need to buy ANYTHING else or will it perform and work forever (not literally forever) and if so let me get this straight, with the 4.5, sye and cv and 31's i wouldnt have to buy any adapters, other kits, parts ANYTHING...just install the lift/shaft/sye and adjust the spedometer and im done right? anything i should worry about or anything?
'79 CJ7 PICS HERE specs in profile
'06 F-350 Diesel crew cab 8' bed SRW 2.5" lift, 35" MT's, straight piped 4" exhaust, EGR delete, tunes
'98 Chili Pepper Red XJ Sport, 4.0 AX15, 4x4 3" lift, 31" AT's
Originally Posted by my_304_cj7 View Post
I used Marvel once before I took my Jeep out on the trails. I didn't get stuck all weekend so I guess it works.
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
TheRyans33 is offline   Reply With Quote
Old 06-03-2005, 12:42 AM   #2
TheRyans33
**** it, lets do it
TheRyans33's Avatar
1979 CJ7
also im not very michanically inclined, i have a few friends who know a thing or 2 about cars but have never done a lift or lowering so my question i guess is how hard is it to do and whatnot...is it basically take one part out put in the new just make sure ya do it in a certain order kinda thing like i think it might be? if its that i think i can do it.
1 April 2007
Old 06-03-2005, 12:51 AM   #3
Low Pressure
you will need new shocks also, installing it is relatively simple, a backyard mechanic will do fine. i would also reconsider and maybe get a 32's or 33's instead of the 31's
Low Pressure is offline   Reply With Quote
Old 06-03-2005, 01:04 AM   #4
silverxj2001
x2. get some doesch tech shocks and run 33's for sure.
for reference here's a pic of my XJ on 4.5" RE coils, 3.5" RE leafs and 33x12.5" procomp A/T's with trimmed fenders (old pic but it works for reference)
2001 2-door XJ prerunner
6.5" RE
33x10.5" BFG A/T KO
15x8" rockcrawlers w/3.75" bs
hannemann 6" bulge flat top fiberglass fenders
bilstein 11" travel 5150's
RE XD trackbar / frame mount
RE adj. LCA/UCA's
beard triple thick limit straps
rusty's steering box brace
truckfarm pre-runner bumper
intake / exhaust
procomp lighting
system... yada yada yada
[URL=http://www.cardomain.com/memberpage/437678/1]PICS OF MY XJ[/URL]
silverxj2001 is offline   Reply With Quote
Old 06-03-2005, 01:06 AM   #5
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
If you can turn a wrench you can install a lift. Yes, it will take more time to do it f you've never doe anything big, but it's worth the time. Arrange to have a alternative form of transportation until the lift s completed.
Study, study, study as much info as you can online. Read the instructions over and over again for a day or two before starting. Take an inventory of ALL the parts in the kit. Copious amounts of PBblaster on ALL nuts and bolts to be loosened or removed.
Take your time!
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 06-03-2005, 01:45 AM   #6
jeepkid8037
Sounds good. Only thing that you did not mention was shims. No big deal. But you will need to rotate your pinion to be directly inline with your driveshaft. Probably the hardest thing to install that you have listed is the SYE. I had a couple problems with mine, just take you time, and before you take everything apart make sure u studied how it goes back together. Sounds like a good setup though. I would try to go bigger than 31's though. Heres a pic of mine w/ rusty's 4.5" lift and 33's
[B][COLOR=DarkRed][COLOR=DarkRed][B]93 xj 211,000 miles
rusty's 4.5" lift
aa sye
tw cv ds
ford 8.8 w/ 4.10 gears and an aussie locker
4.10 gears front
15x8 rockcrawlers w/ 3.75 bs
33x12.5 radial tsl's
no swaybars[/B][/COLOR]
Got her back![/COLOR][/B]
[COLOR=Yellow]http://www.freeiPods.com/?r=17745586 free ipod[/COLOR]
[COLOR=Yellow]http://www.geocities.com/campo4x4/Campolindo_4x4club.html[/COLOR]
jeepkid8037 is offline   Reply With Quote
Old 06-03-2005, 07:43 AM   #7
xj89
Lol i see this jeep in almost any post talking about lifting, haha (show offffffff) jk man im sitting in clas sand bored so i figured id comment on how often i see it, lol nice jeep though. But back on topic i would definetly go with 32's or 33's, and the install wont be to hard. I would recomend buying yourself an xoy map torch, or a prpane torch, or any source of hot hot heat. BEcasue with my jeep i had to heat the old eye bolts on the leafsprings out, and use a 3 foot breaker bar. you can go to any home depot and pick up an oxy map torch for 50 bucks. To me it was worth every penny and PB blaster is a great investment.
74 CJ5
86 CJ7
89 Cherokee
xj89 is offline   Reply With Quote
Old 06-03-2005, 12:27 PM   #8
TheRyans33
**** it, lets do it
TheRyans33's Avatar
1979 CJ7
thanks a lot guys helped a lot, i think im def gunna go with the 4.5 and 33's
1 April 2007
Old 06-03-2005, 06:51 PM   #9
Carp.xj
First off, you''l be able to install it, just get a friend to help, especially if he/she has some knowledge......
CHECK LIST:
-You will get FREE shocks form RE dealers. Doestch Tech....
-Definitely run 33s, they fit best with the 4.5", but you will have to trim a little
-fender flares if you want or have to (the law in your state?)
-don't forget the actual wheels....I would go with black steel cragars or rock krawlers...they run like 35$ a piece from Quadratec.com
-RE 4.5" lift "superflex"
-CV shaft and SYE
-Shims for rear axle (these are little angles pieces of metal which go under your rear leaf springs to help driveshaft angle) order seperately (around $20 from RE).
-PB Blaster
-Basic tool set
-saw zaw or grinder for trimming
-brake fluid to bleed brakes after....
-torque wrench if you want....
-two jack stands, one jack
^^pretty complete list for your install I think......
FYI, after a few months of driving 33s with stock gearing, you'll probably want to go to 4.56s assuming you have an Auto....total parts and install for front and back will run you $800 bucks....
For the record, I drove around with my 3.55s on 33s for a while, and didn;t mind it so much, but it sure is nice to have stock power back again!!
Good Luck
[SIZE=1]'96 XJ country edition, dark blue
4.0L I6 HO, AW4, NP 231
4.5" RE lift, SYE and CV
Dana 30, ChryCo 8.25 (w/ 29 splines), 4.56s
15x8 Cragar steel rims, black
33x12.5 GY MTRs
Bushwacker flares
Warn rear bumber w/ tire carrier
and other stuff....check out my website!!
[B]Sebastian[/B]
[B](SoCal)[/B][/SIZE]
[SIZE=2][URL=http://my-xj.tripod.com]my xj site[/URL][/SIZE]
Carp.xj is offline   Reply With Quote
Old 06-03-2005, 10:32 PM   #10
Dirk
I would have several concerns not discussed yet...
DPG OFF-ROAD
Dirk is offline   Reply With Quote
Old 06-03-2005, 10:35 PM   #11
Silver TeeJay
Dirk:
What would the SYE (Hack/Tap) and CV DS run for 2000 Cherokee?
Just got lifted today and already tired of the slight vibration from 25-35 LOL!
EDIT: Is this a good setup?
A/A SYE & Tom Wood CV Driveshaft
Code: AACOMBO1
Price:$480.00
Get an Advance Adapters Slip Yoke Eliminator Kit along with a Tom Woods CV Driveshaft for one low price. This is for a 231 transfer case.
[B][COLOR="Silver"]2005 Jeep TJ "RME" - Bright Silver Metalllic - 4.0 Auto
2" BDS Coil Spacers / BDS Steering Stabilizer / BDS 5500 CAV Shocks / JKS 1.25" BL / JKS 1" BMML / Dana 44 / 3.73 Gears / Custom Rock Sliders / 32x11.50 BFG KO's / 15x8 AR Diamond Backs
[B][I][U][/COLOR][/B]
[COLOR="Silver"][SIZE="2"][COLOR="Silver"]Proud member of the KC Jeep Club![/COLOR][/U][/I][/B][/SIZE][/COLOR]
Silver TeeJay is offline   Reply With Quote
Old 06-03-2005, 11:22 PM   #12
Dirk
Originally Posted by BlueMonster
Dirk:
Code: AACOMBO1
Price:$480.00
Call me to discuss details & pricing...
DPG OFF-ROAD
Glock Forum
