Knocking Sound ? - JeepForum.com
post #1 of 15 Old 03-31-2006, 08:13 AM Thread Starter
DesertOne
Angry Knocking Sound ?
I have a 1996 Jeep Cherokee Classic 4.0L, 6cyl which has 157k on it. Lately I have been hearing a knocking sound in the engine. It almost sounds like to me that it is the air/gas mixture not right being right. Not sure, just a guess. I had thought about changing the Knock sensor, but low and behold, I can not find any anywhere. Does the knock sensor sound like the right direction on this?
Thanks for any suggestions....
Ted W
Phoenix, AZ
DesertOne is offline
post #2 of 15 Old 03-31-2006, 08:46 AM
AZ Jeff
2014 JK Wrangler
Ted W
Phoenix, AZ
Post Renix machines don't have a knock sensor.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 15 Old 03-31-2006, 10:41 AM
XJ4oh
1997 XJ Cherokee
Bad air/fuel mixture is usually a ping kind of noise. Is the knock coming from the top or bottom end of the engine?
Almost every 4.0 I have heard (including mine) knocks and ticks noticably.
Common causes are sticking lifters, and cracked exhaust manifolds. But it can be more serious like a rod knock, but hopefully not.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #4 of 15 Old 03-31-2006, 01:33 PM
XJ95mlake
1995 XJ Cherokee
my 4.0L HO does not knock or ping or anything. It's as quite as a church mouse. That is, until i hammer the pedal and get the 4.0 HO roar.... sweet.
"Jeep is more than a machine... it's a way of life"
XJ95mlake is offline
post #5 of 15 Old 03-31-2006, 01:52 PM
XJ4oh
1997 XJ Cherokee
Your lucky, haha. How many miles are on it?
And yes, the imfamous 4.0 roar is great. It really is the only engine that sounds like it does.
Baja Aux. Lighting.
XJ4oh is offline
post #6 of 15 Old 04-06-2006, 08:08 AM
92laredo
if it's coming from the bottom end...check the torque converter bolts. mine did the same knock and 3 of the 4 bolts were almost all the way out. just remove the shield and you'll see the bolts
92laredo is offline
post #7 of 15 Old 04-06-2006, 09:07 AM
formatt
2009 JK Wrangler
possible timing chain slap?... The teeth wear down and it gets sloppy in there. is it kind of intermitant?
matthew - 96 xj
formatt fabrications
www.formattfab.com
formatt is offline
post #8 of 15 Old 04-06-2006, 09:20 AM
mjaybird65
mine has the pinging (not bad, but noticeable), but only on low rpm acceleration. typically in highest gear with slight acceleration - not enough to force a downshift... if this is the result of bad air/fuel mixture, what's the best way to figure out how to even this out? or possible remedies?
thanks
2001 Black XJ Sport 4x4
4.0L I6, AW4, NP231, 8.25 rear
mjaybird65 is offline
post #9 of 15 Old 04-06-2006, 10:17 AM
XJAce
thanks
Do you run 87 octane gas? The pinging would go away if you ran mid-grade or even High-test but thats getting pretty expensive now. Even out my way its $2.91 a gallon for high-test. The pinging you hear is called pre-ignition detonation. This happens when the motor has reached normal operating temperature and the combustion temperatures has reached a point were the exhaust that is exiting at the same time the next intake charge is comming in and the exhaust is so hot that it violently ignites the incomming air/fuel mixture(s) and if you comtinue to drive with really heavy pinging your motor is going to be toast. The result of the detonation is a spike in combustion temperatures resulting in fried piston(s) or valves. You can usually tell the signs of detonation even if you can't hear it is when you take the spark plugs out, the center electrode will be melted or even the little hook that lets the spark jump will be melted. Good Luck.......!!
XJAce is offline
post #10 of 15 Old 04-06-2006, 10:41 AM
gaa
I have an 89 xj and it started witha knocking sound a few months ago. It only does it when it's warming up though. Once it reached operating temp it sounds normal.
GWILLYS
gaa is offline
post #11 of 15 Old 04-06-2006, 12:12 PM
mjaybird65
thanks for the info... maybe I'll try to use higher octane until they drop the winter mix and see if that helps. probably time for a tune-up too (at least a check of the plugs)...
post #12 of 15 Old 04-06-2006, 04:40 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
thanks
2000 and 2001's tend to wear out plugs sooner that older XJ's because of the distibutor-less ignition. New plugs are cheap and help with the gas mileage. Pinging or detonation can also be caused by carbon deposits in the combustion chamber or on the valves. Try a tank or two of gas with some mid price fuel injector cleaner added to it. Sea Foam cleaner works well for me.
CJ7-Tim is offline
post #13 of 15 Old 04-06-2006, 05:03 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Man you took the words right out of my mouth. Ive been saying that for years! And its true! I love 4.0's
88XJSport is offline
post #14 of 15 Old 04-06-2006, 05:37 PM
MoochsXJ
2007 WK
I had the same problem but it wasn't the bolts, turned out the flexplate(flywheel) was pretty much shattered and barely hanging in there. She's quieter, but so was I after spending $400 to get it fixed.
'03 Rubicon - DD
Misc. Jeep stuff for sale/free
MoochsXJ is offline
post #15 of 15 Old 04-07-2006, 10:15 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
My 93 has no muffler and an open intake. I love the sounds it makes when I get on it. It just sounds mad.
Derpy Hooves for President in 2012
Matt Gertsch is offline
4WD knocking sound limpfurball XJ Cherokee Technical Forum 8 10-09-2009 02:58 PM
Knocking Sound Hacobo XJ Cherokee Technical Forum 4 01-10-2009 07:03 PM
knocking sound Winkler121 XJ Cherokee Technical Forum 5 10-09-2008 10:30 AM
knocking sound from the pan Dubliner XJ Cherokee Technical Forum 19 03-16-2007 04:37 PM
Knocking sound 92cherokee XJ Cherokee Technical Forum 6 10-09-2002 04:47 PM
