Knocking noise in front differential? - JeepForum.com
post #1 of 4 Old 02-28-2011, 02:14 PM Thread Starter
nyaben
The last few weeks I have noticed that at very low speeds (x < 10 mph) I have heard and felt knocking in my 2000 4.0. By the way the vibrations come through the gas pedal and the steering wheel, it feels like it might be the front differential spinning up (or something other to do with the front differential?). I got the underside hung up a few weeks ago and actually crashed down on it fairly hard (that darn curb drop-off is going to pay ) 4x4 still works fine and I have noticed no problems other than the vibrations. I've read people have figured similar problems to be the exhaust even? It was at least somewhat affected by my little accident as well.
Does anyone have any experience with something like this? I'm still very new to the forum and may not have described this very well, but if anyone has any advice that'd be great.
nyaben is offline
post #2 of 4 Old 02-28-2011, 02:45 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would pull the cover and inspect the gears first.
xjfever is offline
post #3 of 4 Old 02-28-2011, 02:48 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Then inspect the u-joints and check torque and the bushings on the track bar and control arm bolts.
CJ7-Tim is offline
post #4 of 4 Old 02-28-2011, 02:53 PM
dcorn
I had a weird knocking in my rear diff. Turns out 4 teeth had broken off the ring gear. I drove over a bit more than a curb though...
Have you looked at anything in the front axle yet? Check everything that moves when you drive, especially u-joints in the axle and driveshaft.
2014 Jeep Grand Cherokee Summit
dcorn is offline
4x4 , differential , steering , vibrations
Front differential noise? Phil12 XJ Cherokee Technical Forum 8 08-30-2010 02:54 PM
Knocking noise from front left on take off jjay69 XJ Cherokee Technical Forum 0 06-16-2010 03:04 AM
Front Differential noise djkirwin XJ Cherokee Technical Forum 4 06-16-2008 04:32 PM
%&#$@* knocking noise in the front end firehawk XJ Cherokee Technical Forum 5 09-02-2006 10:44 PM
Knocking noise berubeny XJ Cherokee Technical Forum 6 10-24-2005 02:19 PM
