Knock at 60mph and above in front end - JeepForum.com
post #1 of 5 Old 02-13-2011, 07:24 PM Thread Starter
Kutz86
not noticeable at lower speeds. Does seem to get worse the faster i go above 60mph. i saw a few people had similar problems and said front driveshaft. I was driving in 2wd, any thoughts?
Kutz86 is offline
post #2 of 5 Old 02-14-2011, 08:56 AM Thread Starter
Kutz86
bump
Kutz86 is offline
post #3 of 5 Old 02-14-2011, 09:04 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The front shaft spins whether you are in 2wd or 4wd. It could be a u-joint, or driveshaft angle problem, could also be a bearing in the differential. What lift amount do you have and can you describe the sound a little more.
xjfever is offline
post #4 of 5 Old 02-14-2011, 10:03 AM Thread Starter
Kutz86
3.5"in lift on 32x11.5s. checked the u joints when i did the left side wheel bearings, they were good. the sound is hard to explain. it is completely unoticeable under 55mph and quickly builds up once at 60mph and as i accelerate higher it gets worse. the jeep is pulling slightly to the left and rides a little rough but i think that has to do with the tire ware and alignment being off slightly. it doesnt create a wobble or shake its just that clicking/knocking sound over 60.
Kutz86 is offline
post #5 of 5 Old 02-14-2011, 06:48 PM Thread Starter
Kutz86
pulled front drive shaft off tonight and although it rode a little smoother, im still feeling the tapping in the front end over 60mph. i tried swerving side to side tonight and it does seem to be on the left side of the vehicle. ive already changed the wheel bearing on that side and checkd the axel while it was out and it looked fine. the only other two things would be ujoint and wheel bearing that i can think of. would either of those be causing a sound like that?
Kutz86 is offline
Front end vibes 50-60mph ddoffroad XJ Cherokee Technical Forum 9 05-26-2010 03:14 PM
front tires shimmy only around 60mph ??? slegerjr XJ Cherokee Technical Forum 12 07-24-2009 07:51 AM
Front End Knock trev6q8z XJ Cherokee Technical Forum 1 08-05-2006 12:54 AM
Front End Knock trev6q8z XJ Cherokee Technical Forum 3 08-04-2006 09:55 PM
Front End Knock PrimeSuspect XJ Cherokee Technical Forum 3 01-06-2003 02:07 PM
