Kick Down Cable Adjustment? - JeepForum.com
post #1 of 4 Old 06-02-2013, 08:58 AM Thread Starter
RamboPants
1987 XJ Cherokee
I just discovered that i could adjust this. Trans shifts smooth now but do i need to fine tune it or readjust my TPS? I followed the instructions but its leaves my Throttle almost wide open that way. I pushed the plunger back in little by little until the throttle arm just touches the little stopper screw. Shouldn't it do that by itself with my having to do it? Should I just swap in a new on?
RamboPants is offline
post #2 of 4 Old 06-03-2013, 06:15 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
No need to adjust TPS. The cable is supposed to self adjust. Just leave enough slack that it doesn't hold your throttle open. Maybe the thickness of a penny as the amount of slack in the tV cable.
Trans switch in Power or Comfort? Does it light up in Power mode?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 4 Old 06-03-2013, 06:30 AM Thread Starter
RamboPants
1987 XJ Cherokee
Trans switch light burnt out. Its in comfort now. I can tell the difference when its in power though.
post #4 of 4 Old 06-03-2013, 07:16 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Leave it in power.
