keyless entry problem - JeepForum.com
post #1 of 3 Old 07-30-2014, 10:26 PM Thread Starter
dsfdf19
1994 XJ Cherokee
I have a 99 4 door power locks, keyless entry. I have searched with no success, ok here goes.... when you use (lock or unlock) power locks or keyless entry. You can hear the mechanism operating however no lock movement on any door except rear hatch. All lock work (manually) freely key operation is flawless. It's like something is un hooked or broken in all four doors. .. any ideas?
1994 Jeep Cherokee SE 2 Door
6.5 Rustys leaf pack
33-12.50 15 D.C. Crushers
15x10 Rockcrawler Wheels
The Jeep Build W/lots of Pic's
dsfdf19 is offline
post #2 of 3 Old 08-04-2014, 11:18 AM
SSellers
I had to replace three of the four lock/latch mechanisms on my '98. May be the same problem with yours. I'm not certain but I think the lock solenoid attachment to the actuator may be plastic that just breaks internally. Pulled the three out of my wrecked spare parts car and grabbed another half dozen when I was at the junkyard. Pull a panel, remove the rods, and remove the three bolts that hold on one of the mechanisms. Fire the lock button and you'll probably hear the solenoid fire but see no movement on the actuator.
Steiner
1998 XJ Classic driver
1998 XJ Sport spare parts supply
SSellers is offline
post #3 of 3 Old 08-04-2014, 07:18 PM Thread Starter
dsfdf19
1994 XJ Cherokee
Thanks for the information I will try that
dsfdf19 is offline
