Key wont turn in the ignition cylinder - JeepForum.com
post #1 of 16 Old 12-14-2009, 03:57 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
Well my key will not turn it at all! but the issue is to replace the cylinder i have to have the key in the on position! any one know how i can get it out with out the key in the on position or a trick to make this thing work?! My jeep is stuck at work blocking our plow in and the moment and its snowing out pretty heavily so im in a frantic rush to figure out how to fix this. any ideas?
fitbmxseries1 is offline
post #2 of 16 Old 12-14-2009, 04:21 PM
billt79
1995 XJ Cherokee
i broke mine with screwdriver and touched the yellow to the purple though i probably have, different ignition to you because mine jeeps 95 not 99 and i think that all changed in the 96 models, also my ignition and wires have been replaced. hope this helps
2 jeeps, ones fine, no mods the same as the other apart from the others has been hit side on by a damn landrover discovery!!! and now has a bent chassis!! grrrrrr!
billt79 is offline
post #3 of 16 Old 12-14-2009, 05:10 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
i think its different colors on mine. we ended up dragging it out of the way with another truck after putting the t-case in neutral and we dragged it into our shop still unable to get that key to turn so i can pull the tumbler out though! hopfully some one has had the same experince as me and knows what to do.
picked up a new lock cylinderfor 70$ at a dealership and they are charging me 30 to rekey it.. so this is what its like to drop the soap.
post #4 of 16 Old 12-14-2009, 05:18 PM
Mighty Thor
Is your key badly worn? Locksmith can cut you a new key using the numbers and put the cuts back to where they are supposed to be. New key may work well enough to get lock out.
Mighty Thor is offline
post #5 of 16 Old 12-14-2009, 10:08 PM
yooper2001xj
x2 on the new key. Can't hurt to try a cheap option before you rip stuff apart. My girlfriend's car (saturn) was doing the same thing. Tried the spare key, which was new, and works fine.
yooper2001xj is offline
post #6 of 16 Old 12-22-2009, 10:09 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
i got a new key made off the serial number its the tumbler thats bad, after tapping the key with a hammer it was able to turn so i was able to replace the cylinder.
post #7 of 16 Old 12-23-2009, 06:50 AM
Kevin108
Wiggle the key all around inside the ignition. Go to YouTube and look up bump keys or lock bumping for an idea of what to do to your ignition to get it to function with the key you have. Just don't break the key off in there when you're doing all this.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #8 of 16 Old 12-23-2009, 07:29 AM
7urtle
2008 KK Liberty
i had the lock smith rebuild mine for 60 including new keys. if i took it out it would have been 30. i just kept tapping and wiggiling
hit it with a hammer
-1UMF a really slow build. bruised and never left the street
WTB: rear bumper/tire carrier,31" tires,armor
7urtle is offline
post #9 of 16 Old 12-23-2009, 07:35 AM
7urtle
2008 KK Liberty
Originally Posted by BChance0975 View Post
Best NOT to.. but from what I have seen and read sometimes that is the only way to free it up.. what I did last time (not on a Jeep, but similar problem) was a few drops of Kroil and then hit it with compressed air..drove the oil in to all the places it wouldn't go with just gravity, and helped drive all the dust and crap out...did that a couple times, that got it to turn, barely, and I replaced it. Some need to be turned to run to get them out if you don't want to drill.. I THINK, (and I may be wrong, if I am, someone will jump in) that this is one of those you have to turn, then push the tab with a flat blade screwdriver to release. Some just had a retaining screw.
Originally Posted by colt933 View Post
Problem solved:
With the lower steering cover removed, I tapped on the outer ignition lock housing with a small gunsmithing hammer while attempting to turn the key with the other hand. It started to let go on the 5th tap and now it's good to go. I think a tumbler was stuck.
hope this helps
7urtle is offline
post #10 of 16 Old 12-23-2009, 01:55 PM
Kevin108
Glad you got it fixed!
Kevin108 is offline
post #11 of 16 Old 12-23-2009, 03:07 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
kinda funny because a van was towed into work with the same issue yesterday.. least i knew how to fix it right away... darn you Chrysler!
post #12 of 16 Old 12-23-2009, 03:28 PM
keepishop
1989 XJ Cherokee
Silicon penetrating lube in a spray can is what I use to loosen up locks for picking. It might help your ignition if there is something stuck.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #13 of 16 Old 12-23-2009, 06:32 PM
bobjeep
mine broke inside it's made of potmetal, turn key on does your guages come on? if so climb under with A screwdriver and jump the selinoid,will start if you have guages. my tumbler cost 75.00$ at napa,also you need a torx bit with a hole in the middle to take it apart.
bobjeep is offline
post #14 of 16 Old 12-24-2009, 11:27 AM Thread Starter
fitbmxseries1
1987 YJ Wrangler
on i think 97 and newer you can only go to a dealer or maybe its 99 and newer.
post #15 of 16 Old 01-14-2010, 07:02 PM
JoBo
I got a call from the wife this morning. "my key won't turn"
She's been complaining about it but it always works for me
Not this morning.
I had AAA tow it home from the grocery sore. the FSM says to turn it to on, push the release thing and pull it out. Sounds good but the only reason I wanted it out was because it would not turn
So I did a search and found this thread.
Tapping on the end of the key did the trick
A new cylinder at the local dealer was $128 and with the vin they looked up the key code and keyed it to fit my keys for an additional $30.
Not cheap but a simple fix.
thanks for the tipe
Joe
JoBo
Columbus, Ohio USA
2006 KJ CRD Atlantic Blue Pearl Coat Limited
2000 Cherokee Classic with factory 16" wheels
JoBo is offline
2001 Cherokee ignition lock cylinder won't turn colt933 XJ Cherokee Technical Forum 20 08-12-2016 05:46 PM
Key wont turn in ignition, cannot get cylinder out Tommyboy75861 XJ Cherokee Technical Forum 3 12-07-2008 07:47 PM
Key wont turn in ignition tangofox007 XJ Cherokee Technical Forum 9 08-30-2007 03:57 PM
HELP!!! Ignition wont turn BlacknRedGT XJ Cherokee Technical Forum 19 03-12-2007 03:00 PM
Ignition Cylinder will not turn all the way back. RickyN29 XJ Cherokee Technical Forum 1 05-03-2006 07:12 AM
