Key gets stuck in Ignition - JeepForum.com
post #1 of 12 Old 10-29-2010, 07:25 PM Thread Starter
DDavee
1997 XJ Cherokee
I have a '97 Cherokee Country. The key sometimes doesn't come out of the Ignition. I have to take it for a little drive and when I come back it works. Now, for the past 2 days I tried having it in 2WD when I turn the car off and it's worked... However, it sometimes does and sometimes doesn't. So it's impossible to tell if the 2WD fixed it, or if its something else.. I heard it may be because I don't have the steering wheel straight, I don't know though.. Advice?
DDavee is offline
post #2 of 12 Old 10-29-2010, 07:56 PM
PlatinumNiner
Maybe its not 100% in park? Could be the steering wheen lock, Whats the condition of the key? If its the oem key from 97 i doubt its on good shape. Dealer can cut you a new key using your vin for about 15 bucks. hats what i did for my 95 then just had a few copies made. Did it this way so i had a perfect key to start with.
PlatinumNiner is offline
post #3 of 12 Old 10-29-2010, 08:00 PM Thread Starter
DDavee
1997 XJ Cherokee
I have one that looks like its the one that came with it, but I have one thats much newer. The newer one that stuck one time, however that couldve been because that one time it wasn't parked right... Ugh, I wish it happened all the time atleast then itd be easier to pinpoint/
DDavee is offline
post #4 of 12 Old 10-29-2010, 08:08 PM
ergolarry
1994 XJ Cherokee
What would having it in 2wd have to do with the key coming out? There is an interlock between being in park before the key is released in a lot of vehicles, but to my knowledge there is no relationship between the transfer case and the column. You can also try lubricating the lock mechanism with dry graphite, however my bet would be on a worn lock mechanism due to regular use and age. As the lock and key wears, the tumblers in the lock aren't moved as much and interference within the lock prevents proper function. On the positive side, after having torn my column apart for turn signal switch replacement, the replacement of components within the column aren't too overwhelming with a FSM and required tools.
ergolarry is offline
post #5 of 12 Old 10-29-2010, 08:23 PM
PlatinumNiner
The signal switch can be replaced in like 20 mins thats super easy on the newer 95+ columns. Im not sure how much work it is to replace the cylinder. I wouldnt jump to that though id check everything else first.
post #6 of 12 Old 10-29-2010, 08:31 PM Thread Starter
DDavee
1997 XJ Cherokee
Is there a way to tell, like if I had a garage put it on a scope?
DDavee is offline
post #7 of 12 Old 10-29-2010, 08:35 PM
PlatinumNiner
Nope. If you have a perfect key, you play with the shifter and that doesnt help, you turn the wheel and that doesnt help, chances are its the cylinder.
post #8 of 12 Old 10-29-2010, 08:47 PM Thread Starter
DDavee
1997 XJ Cherokee
next time it happens I will play with the shift..> For whatevewr reason I didn't think of it.
Another question.. When switching between 2wd and 4wd etc... Will it seem like I'm switching? I can move back and forth withoout it seeming like im doing anything.
DDavee is offline
post #9 of 12 Old 10-30-2010, 08:46 AM
jsmiddleton4
1997 XJ Cherokee
I had same problem. It was the manual lock out that had fallen out of the back of the key cylinder assembly. Plugged it back in and it was fixed. You'll need to take the steering wheel column cover off, at least the bottom half, to see.
jsmiddleton4 is offline
post #10 of 12 Old 10-30-2010, 08:58 AM
blankskates15
I had a problem last year with my key getting stuck in the ignition, i had a to have a lock smith come and take a look at it, he said that the waffers they use in most jeeps and other cars are really cheap and bend and shear after awhile. he looked at mine and he was right, also i had alot of dirt and debris build up which was causing the key to stick. use some silcon lubericant and spray it in your tumbler and slowly move the key in a out to try and lubericate and clean your ignition. also tapping on the butt end of the key while it is in can work too, but do this very lightly, it can free up the waffers and knock dirt loose.
blankskates15 is offline
post #11 of 12 Old 10-30-2010, 09:02 AM
Apostle
Have to push button on my shifter to get my key out, every time. i've learned to live with it
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline
post #12 of 12 Old 10-31-2010, 05:24 PM Thread Starter
DDavee
1997 XJ Cherokee
Thanks everyone. All I have to do is push up on my shifter and it works. Key comes out everytime.
DDavee is offline
Key Stuck in Ignition 98 XJ yingpin XJ Cherokee Technical Forum 4 08-02-2010 06:54 PM
Ignition key is stuck fireflyer141 XJ Cherokee Technical Forum 6 04-14-2010 08:50 PM
Key stuck in ignition! How do i replace ignition switch? Jmila1901 XJ Cherokee Technical Forum 10 10-16-2007 12:09 PM
My key is stuck in the ignition!! how do I get it out? danielhays_98xj XJ Cherokee Technical Forum 9 09-18-2007 11:04 AM
Key stuck in Ignition jaardesign XJ Cherokee Technical Forum 9 05-03-2006 05:29 PM
