Quantcast Key Fob issue... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Key Fob issue...
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 12-29-2009, 11:21 PM   #1
ChargerX3
Key Fob issue...
So i just purchased my XJ last month, but it didnt come with any key fobs. Its the limited model, so im sure it came with them. The last owner didnt get any when he purchased the jeep used, but the dealer said that it came with them and that he would get them to him. Well, that never happened.
So i did some ebay shopping and picked up some Grand Cherokee key fobs for 96-98 model years. I figure they are the same as XJ's so i jumped on them. Well ive been looking through all of the DIYS stuff and none of the tricks seem to be working. I also did a search on here and it says that i need to take them into the dealer to have some sort of tool to program them to each other.
What should i do? What is the real way to program these babies? I really want to get these working...and hopefully by myself not the dealer.
ChargerX3 is offline   Reply With Quote
Old 12-30-2009, 04:34 AM   #2
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
The only way to program new key fobs to your 1997-2001 Cherokee is at the dealership. Some charge a fee for the programming and some will do it for free if you are having other service work done.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 12-30-2009, 07:27 AM   #3
FG Jeep
97-01 xj's require a drb3 to program. a lot of independent shops have them now with all the dealers that went under.
The other way is go to a jy and try to find a key fob, pass side window switch (which is the door module on an xj) and the little rf receiver board in the overhead ceiling light. all three of those from the same jeep will be coded together and the keyless will work. I did this on my 98.
1998 XJ Sport
1998 ZJ 5.9 Limited for sale see my link on jeep forum.
http://www.jeepforum.com/forum/f153/1998-jeep-grand-cherokee-5-9-limited-1286243/
FG Jeep is offline   Reply With Quote
Old 12-31-2009, 10:14 AM   #4
ChargerX3
Thanks for the tips guys. If i do go to get it re-coded will the 98 grand cherokee fob work on my 98 xj cherokee, or are they different systems?
Old 12-31-2009, 10:19 AM   #5
Leo_1969
1991 XJ Cherokee
Should work fine - it was the same system mounted in XJ and ZJ.
4.0 / NP231 / TrueTrac rear / BRC liquid gas equipment / Lift 3" / SkyJacker Nitro 8000 / Maxxis Bighorn MT-762 31x10.5 R15 / 13000 lbs behind original bumper :)
Leo_1969 is offline   Reply With Quote
Old 12-31-2009, 10:24 AM   #6
ChargerX3
If they are the same then why cant you program them both the same? Why can one be done in your driveway, and the other have to be set up at the dealership?
Old 12-31-2009, 11:13 AM   #7
Leo_1969
1991 XJ Cherokee
As far as I know /correct me if I'm wrong/ both could be programmed in your driveway, but you need one original KeyFob + 2 original keys - then you can program any other new bought key fob. If you haven't any working Key Fob, then it must be programmed wit help of DRB3.
Old 12-31-2009, 02:54 PM   #8
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
The remote fobs may or may not be the same part number, ZJ vs. XJ.
1997-2001 XJ's require the DRB-III scanner to program the key-less entry.
PM me for details
Old 12-31-2009, 03:14 PM   #9
throttlejunkie1
Don't know if this is relevant, but auto parts stores have a little device at the front counter that, once your fob buttons are pushed, will indicate whether or not the signal is even being sent. This might help you later...
2000 XJ, Patriot Blue, 4.5 RC, AR-767's, 31x10.5 BFG AT's, Surco R/R, tint, Baha's x6, aux fan mod, SOLD....
September 11 2001
Never Forget!
throttlejunkie1 is offline   Reply With Quote
Old 12-31-2009, 08:12 PM   #10
ChargerX3
Yea, but i dont have that chip thing in my key, so do i really need 2 original keys? I also dont have an original key fob, so i take it im SOL? BTW what is the programming method for the XJ key fobs without using the DRB3? Thanks again for your help
May or may not? Is there a way i can check my part #?
That sure can help me find out if my battery is dead or not in the two.
Thank you all for helping. I feel im starting to figure this out.
Old 01-01-2010, 12:50 AM   #11
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
SKIM security chip keys are not the same thing as key-less entry fobs. SKIM security system keys are usually gray in color and larger than the skinny black non-security system key.
Key-less entry fobs can ONLY be programmed with a DRB-III scan tool at the dealership or repair shop.
1997-2001 XJ Cherokee key fobs are imprinted on the backside with Chrysler Part Number 56036859 and Model/FCC GQ43VT9T.
PM me for details
Glock Forum
