Keep blowing 60 amp Maxi Fuse, Alternator Output - JeepForum.com
post #1 of 8 Old 06-29-2013, 07:52 PM Thread Starter
garand555
I noticed this afternoon that the the voltage gauge was reading way low. Before yanking the alternator off, I decided to check the Alternator Output fuse in the power distribution box under the hood, and it had popped. So I went up and picked up a new one, put it in and it lasted, oh, about 5 minutes. The other thing is that, before the new fuse popped, the voltage guage would change with the RPMs, which it never did before.
I put the multimeter on the battery and it read 11.8V, so I'm thinking that a cell went bad and that's causing a much higher current draw than it should, and will get it checked out tomorrow. It could be that the fuse had popped a while back and I'm just now noticing it, but I find that doubtful as I pay attention to all of the guages on a regular basis.
Is there anything else I should be on the lookout for?
garand555 is offline
post #2 of 8 Old 06-29-2013, 08:00 PM
jeepster383
Ur alternator could have went or u have a short. Check the wire going from batt to alt.
jeepster383 is offline
post #3 of 8 Old 06-29-2013, 09:42 PM Thread Starter
garand555
I was hoping you wouldn't say that. The battery is still under warrantee and it's easy.
post #4 of 8 Old 06-30-2013, 11:36 AM Thread Starter
garand555
Well, I decided to check the voltage that the alternator was putting out. 19V . I think that explains why the fuse was blown.
post #5 of 8 Old 06-30-2013, 12:22 PM
jeepster383
Dang. At least u figured it out.
post #6 of 8 Old 06-30-2013, 04:00 PM Thread Starter
garand555
Had the alternator tested. It's fine. Went through and I can't find any bad connections. When I checked the voltage, the battery was connected, so if there was a short in the battery screwing things up, it would have showed up. I'm hoping it's not the voltage regulator.
post #7 of 8 Old 06-30-2013, 04:27 PM Thread Starter
garand555
Aaaand the battery just checked out as good. Either there's a loose connection that I missed that's screwing with the voltage regulator, or it's the voltage regulator. If that's the case, it's either junkyard diving, or figure out wtf this is about:
http://www.oreillyauto.com/site/c/de...tage+regulator
Because it comes up as being for a 92 XJ, even though I thought the regulator was integrated into the ECM. I think I'll go double check all of the wiring.
post #8 of 8 Old 06-30-2013, 09:31 PM Thread Starter
garand555
I think it's fixed. I checked several connections, and since the alternator was out and was the original alternator, I replaced it with a 120 amp one anyway. (Jeep's gotta be reliable for my hunt in December ) Knowing my luck, I'd put it back in and it'd go bad within a month and I'd have to yank it off again. Which would make me really, really grumpy. I replaced the terminals on the battery cables as they looked kind of trashed. After consulting with the internet, I found some people who said that poor grounds and poor connections to the battery can cause the voltage regulator to go a little bit screwy when the battery starts to get low, and sometimes the voltage will get bumped up to 19v. I guess I'll know for sure in a few days if it's fixed.
I really want to punch the engineer who decided to put the alternator below the AC compressor and kick the engineer who set up the tensioner system for the serpentine belt. I can change the alternator on my dad's powerstroke in 15 minutes flat, but noooooo. When an engineer does a really good job, you don't even know that they exist. When they make maintenance a PITA, you want to go to their house with a mob that is wielding torches and pitchforks.
