Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Rough Country TJ Belly Pan Skidplate Giveaway - NEW PRODUCT RELEASE
Best place to buy Rubicon Express! Don't Fear the Jeeper!Insane Rough Country Deals Call for more Info!!! so insanBarnes 4WD Universal 4 Link Kit
Go Back   JeepForum.com > Models > Cherokee & Comanche Forum Group > Cherokee Technical Forum
Jeep Registry Register Blogs FAQ Mark Forums Read Search Members
Old 01-15-2010, 03:03 PM   #1
bmyohn
Youngin'
bmyohn's Avatar
Is this just a NSS issue?
My jeep has been acting up lately. Long starts, cranks longer than it usually does to get the jeep to start. No reverse lights (first sign of a faulty NSS).
Now the weird part is, it wont shift out of first gear. I will be going 25mph down the road at 5,000 RPM's. If i quickly jump on the gas I can get it to shift into second, but it wont do it by itself. Secondly, if i am going 30 mph and i get back on the accelerator it feels as if the jeep is in neutral like there is no power going to the wheels whatsoever.
Are all of these issues stemming from a dirty NSS? I am getting ready to go clean out the NSS here in a few minutes, but i just wanted to be sure that I am not heading in the wrong direction with this.
(the check engine light is on, but I'm not going to drive up to the auto parts store doing 25mph at 5,000 RPM's anymore, its really really really loud)
2001 Dodge Ram 2500 SLT 4x4
5.9L Turbo Cummins Diesel
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
Blue Jeep Club #230
bmyohn is offline   Reply With Quote
Old 01-15-2010, 03:07 PM   #2
Magus2727
Magus2727's Avatar
1995 XJ Cherokee
Ussualy a NSS will not make it slow to start, from what I have seen. When I had a bad NSS and had to clean it out it would not start in gear and i would have to go though gears a few times before stating but when it did it started up as it normaly does. Check the battery?
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline   Reply With Quote
Old 01-15-2010, 03:10 PM   #3
CJ7-Tim
locked and loaded
CJ7-Tim's Avatar
Test the TPS.
For Sale -> XJ Dana 44 rear axle. PM for details
SUV's get groceries, Jeeps get dirty.
CJ7-Tim is offline   Reply With Quote
Old 01-15-2010, 03:12 PM   #4
bmyohn
Youngin'
bmyohn's Avatar
i just changed the TPS not too long ago, I've replaced it twice, this doesnt feel like the same type of issue though.
I guess I'll go up to auto zone and get them to pull the code, if it is the TPS again I have the one with the lifetime warranty
Blue Jeep Club #230
Old 01-15-2010, 03:30 PM   #5
CJ7-Tim
locked and loaded
CJ7-Tim's Avatar
AutoTardZone. I suspect your TPS is failed. The TPS and CPS are the two 4.0L parts that I ONLY get from Chrysler/Jeep. Too many people have had problems with low cost parts not being able to do the job or last very long.
Old 01-15-2010, 03:48 PM   #6
everhguevara
1997 XJ Cherokee
"Secondly, if i am going 30 mph and i get back on the accelerator it feels as if the jeep is in neutral like there is no power going to the wheels whatsoever"
same thing happened to me a while ago, check engine light was on , i replaced the o2 sensor located before the cat. converter and that took care of the problem, good luck.
everhguevara is offline   Reply With Quote
Old 01-15-2010, 04:35 PM   #7
bmyohn
Youngin'
bmyohn's Avatar
Originally Posted by CJ7-Tim View Post
AutoTardZone. I suspect your cheap crappy TardZone TPS is failed. The TPS and CPS are the two 4.0L parts that I ONLY get from Chrysler/Jeep. Too many people have had problems with low cost parts not being able to do the job or last very long.
thanks for the help Tim, you were right on with the advice. My autozone TPS is still under warranty so i got another one for free.
I bought ya a 6 month subscription for your help buddy!
Blue Jeep Club #230
Key Fob issue... ChargerX3 Cherokee Technical Forum 10 12-31-2009 11:50 PM
Odd A/C issue mrtosh Cherokee Technical Forum 2 06-22-2009 11:47 AM
A/C Hub Issue doctorcherokee Cherokee Technical Forum 3 01-22-2008 12:05 PM
Tranny issue, Computer issue? HELP! bassakwardsxj Cherokee Technical Forum 1 05-13-2006 11:11 PM
got an issue kemicalburns Cherokee Technical Forum 9 09-08-2004 08:02 AM
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
