just got a jeep for graduation, having problems. HELP PLEASE. - JeepForum.com
post #1 of 5 Old 07-03-2012, 10:50 PM Thread Starter
1998daisy
I need some help. Just got a 1998 jeep Cherokee 4.0 auto. The question I have is after the jeep is warmed up it will start to misfire and act like it wants to stall. If it doesn't stall it will rev up to 2000 ramp then drop to normal idle. It has done this several times if anyone has any information I would appreciate it.
1998daisy is offline
post #2 of 5 Old 07-03-2012, 10:51 PM
Xpress
Needs to be posted in the appropriate section.
All about that unibody life.
Xpress is offline
post #3 of 5 Old 07-03-2012, 10:53 PM
KEH1997
First--what kind of Jeep do you have...?
Sounds like it could be a bad sensor. If you're a DIY-er, start with the upstream O2 sensor and unplug it from the wiring harness. If the problems stop, then replace that sensor. If not, plug it back in and try others. Could also be an exhaust leak. Check for cracks in the exhaust manifold (especially common on TJs).
KEH1997 is offline
post #4 of 5 Old 07-03-2012, 11:09 PM Thread Starter
1998daisy
Sorry new to this forum, Its a jeep Cherokee 98 4.0 auto. Sorry the putting it in the wrong forum, which would i go to. I need to fix it ASAP for work. I was sent home early because it was acting up. ):
post #5 of 5 Old 07-04-2012, 08:42 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
It sounds like you are describing some sensor issues that occur when the the Jeep switches to closed loop operation.
Test the O2 sensors, they can get old and slow to react. Typical O2 sensor service life is about 100,000-150,000 miles.
CJ7-Tim is offline
bucking , misfire , o2 sensor , rough idle , sputering , stall , stalling
