just finished major cooling system overhaul, still overheating... - JeepForum.com
post #1 of 6 Old 07-18-2009, 01:28 PM Thread Starter
in_motion
i just finished replacing a block plug, water pump and various hoses on my 95 4-banger. everything works superbly but its still overheating. is this an issue with the thermostat? a deeper problem? i've taken it on a few shake down runs and it overheats after 25 minutes. if i turn the heater on full blast, the warning light goes off.
thanks in advance for your help!
in_motion is offline
post #2 of 6 Old 07-18-2009, 01:44 PM
lathan888
1993 XJ Cherokee
if you changed the waterpump you should have gone ahead with the themostat. I would also check the fan clutch. If those dont do the trick then the radiator.
Owner of a 1 owner 93 XJ county trim, 4.0, AT, 8.25 rear and 3.5 gears. It has goodies like pw/pl, cc, tilt, cd changer, keyless entry, rear wiper and defrost...overall a nice old jeep, my fifth owning previous wanglers and commander
[/COLOR] also own/restored a 1972 Pontiac Lemans GT originally owned by my grandmom....39k original miles.
lathan888 is offline
post #3 of 6 Old 07-18-2009, 02:03 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would change the t-stat and radiator cap also. Did you flush the system well? You could have a blockage somewhere. And like stated above if the fan clutch hasn't been changed in a while I would change it also. Is it overheating at idle, or going down the road, or at all times?
xjfever is offline
post #4 of 6 Old 07-18-2009, 02:28 PM
Paradise XJ
1988 MJ Comanche
Major overhaul??
Water pump and some hoses?
Major overhaul:
Flush radiator, heater core, clean out overflow.
T-stat
Water pump
Fan clutch
All Hoses
Heater Valve - replace or omit
Belt
Check e-fan, and a cap.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #5 of 6 Old 07-18-2009, 07:16 PM Thread Starter
in_motion
i've noticed it at all times, going down the road and at idle sitting at a light. i guess the t-stat will be the next thing to change. thanks all for your responses!
post #6 of 6 Old 07-18-2009, 08:12 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
That is what I would do, and I would flush the system very well while it is out.
xjfever is offline
what to buy before cooling overhaul tozier9 XJ Cherokee Technical Forum 10 06-19-2007 09:42 PM
What would you do? (major overhaul work) yoandkids XJ Cherokee Technical Forum 4 12-07-2005 12:15 PM
Cooling System Problems - Overheating 95Cherokee- XJ Cherokee Technical Forum 4 02-16-2005 05:47 AM
Cooling system overhaul fourlow XJ Cherokee Technical Forum 9 08-11-2004 12:00 AM
Looks like I get overhaul the cooling system isezumi00 XJ Cherokee Technical Forum 4 05-04-2004 12:08 AM
