Quantcast just did hubs and... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > just did hubs and...
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 02-24-2008, 07:48 PM   #1
bikedude189
1993 XJ Cherokee
so i just replaced my front hubs and as im driving around i noticed a pretty good vibe from the front end. i thought about it and realized that i took out the axle shafts (just to see...) and i didn't put them back in the same position/rotation that i took them out. does this matter and could it be the cause of my vibes? thanks all!
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline   Reply With Quote
Old 02-24-2008, 08:39 PM   #2
bikedude189
1993 XJ Cherokee
BUmp........
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
Old 02-24-2008, 08:41 PM   #3
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
What did you torque the hub nuts to?
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 02-24-2008, 09:00 PM   #4
glatt513
1994 XJ Cherokee
Don't make a bit of difference. I changed u-joints in my D30 front axle last fall and we had those things contorted so many different ways trying to get the u-joints out I'm positive they did not go in the way they came out by the time we got it all back together. No vibes in mine, though. Did you evenly torque the 3 bolts that hold the hub in there? How tight did you get the big 36mm axle nut? Mine (no torque wrench used) are super tight.
glatt513 is offline   Reply With Quote
Old 02-24-2008, 09:22 PM   #5
bikedude189
1993 XJ Cherokee
i torqued the mounting bolts evenly and the pre load nut (36mm) to about 175 ft-lbs. the vibes may not be associated as the jeep is nice and old and has some "character"... i was mostly wondering about the shafts...
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
Glock Forum
