Just broke something.. - JeepForum.com
post #1 of 8 Old 02-01-2012, 08:04 AM Thread Starter
Glavus
Ok, so I was pretty curious as to how my valves looked, and to see if there was any sludge build up. Here are the results..
Now here's where I broke something on top of the valve cover, it was a PITA to get off so it snapped off. I'm not exactly sure what it is, if someone could tell me what it is that'd be cool. Anyway the Jeep runs fine, and the valves are pretty friggin clean.
Glavus is offline
post #2 of 8 Old 02-01-2012, 08:06 AM
wwch99tj
wwch99tj is offline
post #3 of 8 Old 02-01-2012, 08:07 AM
mtb_crzd47
Crank Case Ventilation valve (CCV).
2000 WJ LTD Shale Green metallic, stock for now
2007 Yeti AS-X, Avid Code 5's Rockshox Totem,
SOLD: 91 XJ
mtb_crzd47 is offline
post #4 of 8 Old 02-01-2012, 08:09 AM
CCKen
CCKen's Avatar
That's the crank case ventilation (CCV) fitting. OEM P/N 53030495.
Dealer has them.
CCKen is offline
post #5 of 8 Old 02-01-2012, 08:14 AM Thread Starter
Glavus
Alright sweet, the part is only $3 at Rockauto. But I'm kind of curious what purpose does this part serve? The Jeep runs fine, it just sucks air out the hose now.
Glavus is offline
post #6 of 8 Old 02-01-2012, 08:19 AM
wwch99tj
It just recirculates the crankcase air through the engine to be burnt and send out the exhaust
wwch99tj is offline
post #7 of 8 Old 02-01-2012, 09:46 AM
jeepgldgr
1988 XJ Cherokee
let me know how you removed it and if you have to remove the valve cover to do so I tried to pry mine out and it doesn't seem to want to come out
jeepgldgr is offline
post #8 of 8 Old 02-01-2012, 10:09 AM
CCKen
CCKen's Avatar
I had to distroy mine getting it out because the grommet was so old and hard. You should get a new grommet while you're t it.
CCKen is offline
My TC broke. sktr021 XJ Cherokee Technical Forum 4 06-01-2010 10:19 AM
Its broke in now! Spokes XJ/MJ Cherokee Non-Technical Forum 6 05-30-2009 02:26 PM
4-lo broke? jackedupxj XJ Cherokee Technical Forum 6 06-03-2007 11:29 AM
Broke Something...PIC onlyinajeep07 XJ Cherokee Technical Forum 5 04-20-2007 11:09 PM
Im broke and looking.... Midtown469 XJ Cherokee Technical Forum 7 01-25-2006 10:07 AM
