Just bought an '89 XJ Limited...a few questions - JeepForum.com
post #1 of 4 Old 01-22-2007, 09:53 PM Thread Starter
maalox
1989 XJ Cherokee
Hi guys. I just picked up an '89 Cherokee Limited a few days ago, and I have a few questions:
1. There is a "screen" below the clock in the dash, next to the radio and heater controls. Is there supposed to be some sort of display there?
2. What is the screen between the visors supposed to display? The lens in mine is cracked, and was glued back together by the previous owner, and it doesn't show anything. I pulled the lens off, and there are some sort of electronics behind it, but I'm not sure what they are for.
3. The power locks don't work. When you push the button to lock them, all of the lock buttons above the door handles twitch, but none of them lock. The PO told me that this was a recurring problem with the truck, but had no idea what the fix was.
4. The rear wiper doesn't work. Fuse is good, I haven't checked to see if it's getting power back there. Just figured I'd fish to see if there are any typical issues with it.
Thanks in advance for the help, I'm sure I'll have more questions as time goes on.
maalox is offline
post #2 of 4 Old 01-22-2007, 10:04 PM
Chris_Walker
Chris_Walker's Avatar
1988 XJ Cherokee
1. It's just black plastic. I thought it was some kind of screen too when I bought mine. It's just that, the circuitboard for the clock is so big, they had to put something there.
2. The screen between the sunvisors is the reciever for the keyless entry. If you can find a remote, you can program it yourself.
3. You lock actuators and linkage is prob getting stuck. Buy some lithium grease and spray the linkages behind the door panel.
4. Turn it on and put your ear by it to see if you can hear it buzzing. The motor might just be burnt out. It's an easy replacement.
-Chris
Chris_Walker is offline
post #3 of 4 Old 01-22-2007, 11:47 PM
jrock
The "screen" below the clock is for the systems sentry, I think only available on 84-85 trucks, and even then an extremely rare option. I found this on naxja.org:
http://www.naxja.org/forum/showthrea...ighlight=oddly
Scroll down to the bottom- you can't miss it
jrock is offline
post #4 of 4 Old 01-23-2007, 06:32 AM
Chris_Walker
1988 XJ Cherokee
Wow, that's crazy. I want one.
Just bought a 1990 Limited XJ PoisonFreeWill XJ Cherokee Technical Forum 3 08-26-2009 09:17 AM
Bought another xj and have some questions.. WHITEXJ7 XJ Cherokee Technical Forum 8 02-03-2009 04:42 PM
so i bought a pretty big 1990 cherokee limited 53_willys_1_ton XJ/MJ Cherokee Non-Technical Forum 28 11-19-2008 10:19 PM
Questions about '97 XJ (just bought) tarvis XJ Cherokee Technical Forum 7 09-19-2005 05:38 PM
Just bought - a few questions HailStorm XJ Cherokee Technical Forum 4 01-27-2004 09:24 AM
