Just bought an 86 XJ, questions.... - Page 2 - JeepForum.com
post #16 of 21 Old 07-03-2013, 09:02 PM Thread Starter
Tyler980
Could that also affect the rough cold idle?
Tyler980 is offline
post #17 of 21 Old 07-04-2013, 07:34 AM
Pats94
Could somehow but I'd suspect other causes.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
post #18 of 21 Old 07-04-2013, 10:17 PM Thread Starter
Tyler980
Awesome, I'll tighten them up and check it out. Another question... Like I said with the cold start the idle is rough and it stalls... well after i had it running for quite a while today I parked, sat for a few minutes, then I put it in reverse and it stalled right out. So I started it back up and put it in reverse, and the idle in reverse is really rough, could this be vacuum as well?
Tyler980 is offline
post #19 of 21 Old 10-07-2013, 08:03 PM Thread Starter
Tyler980
Originally Posted by chris87xj View Post
Could very well be a vacuum leak causing the cold rough idle. 1986 was during the Renix era which brings some unique quirks. Is your a 4 or 6 cylinder?
Oh and you're right about the tire width causing the rear of the inboard front tire to rub on the LCA during sharp turns. You can use a washer or two to shim the steering stops out to where it won't turn far enough to rub, but if you drive it very often you'll soon know just how far you can turn the wheel before it rubs.
Could you show a picture of where I'd put these washers, sorry to bring back my once dead post... I'm just not sure where to put the washers so they don't rub, I don't care much about losing the turning diameter, its my gfs xj anyways, so I'd rather her not rub them all the time till a tire gets shaved off. Lol
Tyler980 is offline
post #20 of 21 Old 10-07-2013, 09:02 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Check this out. XJ steering stop adjustment
Usually steering stops are adjusted by loosening the locking nut and screwing the bolt in or out however, Cherokees have spot welds on the bolts to secure the nut. In that case, unscrew the bolt and add washers as needed. 31x10.5″ tires on stock rims may need two washers on each bolt.
When adjusting the stops, keep in mind that the driver’s side bolt will keep the passenger’s side wheel from rubbing the control arm, and vice versa.
***Chris***
chris87xj is offline
post #21 of 21 Old 10-07-2013, 09:15 PM Thread Starter
Tyler980
When adjusting the stops, keep in mind that the driverís side bolt will keep the passengerís side wheel from rubbing the control arm, and vice versa.
Thank you
Tyler980 is offline
