just bought a 2000, heater will not turn off
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full |
#1 | |
whats goin on guys, i just recently bought a blue 2000 xj, and i got it for a steal heres the problem, when i turn the switch with red and blue on it to change from hot to cold, it feels as though it moves too easy, no matter what i set it on a/c, heat hot, cold, it still only blows hot air, what could be the problem, if anyone knows or has experienced this i would apreciate it if you all chimed in thanks a lot guys... wesley dean
blue jeep club member 174 2001 xj- 2 inch bb moabs 1998 zj 5.2- 245/75's moabs |
#2 |
You have a vacuum leak somewhere. Check all the lines and canister for wear/holes etc
#3 |
If his actual switch feels broken, that could be the problem too I would think. Turning easy may mean the actual knob has separated from what it turns. Pop the big trim/bezel off of there and take a look at it.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
