Just bought a 2000 classic..Cruise not working
#1 | |
So I had a shift in job duties and work and now need to commute about 140 miles a day once or twice a week.....the YJ is no longer ideal for this so i decided to buy a better daily driver....one with ac and cc
So I found a killer deal on a 2000 classic with only 77k on it. Its in excellent condition and am stoked to have found it. A few minor glitches....the most annoying is the CC doesnt work. When I hit on/off sometimes the cruise light comes on and then goes off. Sometimes it never comes on at all?? What should I check into?? Would a broken line cause the light to shut off or would it be a module?? Please help as I want cruise for monday's drive ![]() And of course I cant leave this beast stock gonna throw a little lift and some custom bumpers on it down the road :O)
<>< Turn your face to the Son, and the shadows fall behind you 94 YJ 4.0L, BDS 4 1/2", 1" BL, 33 x 12.50, SYE & Tom Woods drive shaft, 8.8 w/lsd, Aussie Locker front, T & T Phantom tube fenders, Warn rock sliders custom cut, TJ rear flares and Fuel filler, Warn M8000, Custom front & rear bumpers w/swing out, bad apple diff guards, Dual 1400 amp Kinetic Energy batteries, HO alternator, 2 guage comp wires, VIAIR 450c, WRX seats, and way too much more to list. No end in sight!! |
#2 |
Maybe a bad clockspring!
#3 |
Little Red Menace
Start simple and look at the vac line under the hood first. Should be on the pass side fender near the firewall.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#4 | ||
#5 |
I just did a search on the clockspring and it appears that symptoms usually indicate a bad horn as well. I checked and my horn still works?? Could it still be a clockspring?? Im gonna remove the switches here in a few and see if the switch is cracked?? Also going to check the brake pedal switch??
<>< Turn your face to the Son, and the shadows fall behind you 94 YJ 4.0L, BDS 4 1/2", 1" BL, 33 x 12.50, SYE & Tom Woods drive shaft, 8.8 w/lsd, Aussie Locker front, T & T Phantom tube fenders, Warn rock sliders custom cut, TJ rear flares and Fuel filler, Warn M8000, Custom front & rear bumpers w/swing out, bad apple diff guards, Dual 1400 amp Kinetic Energy batteries, HO alternator, 2 guage comp wires, VIAIR 450c, WRX seats, and way too much more to list. No end in sight!! Last edited by pwoens; 08-05-2007 at 11:13 AM.. |
#6 |
so here's an update....checked the lines and they are good. I think I have ruled out the clock spring as everything else that is usually affected by a faulty clock spring, still functions fine. Yesterday on a little road trip it actually turned on and ran for about 3 minutes and then shutoff. Most of the time when I hit the "on" button the light never lights up on the dash. Then sometimes it will but usually shuts right back off??
any other ideas??
#7 |
someone out there has to know how cruise control works?? please
#1) I am trying to figure out if a cracked line would cause the dash light to not turn on sometimes? #2) if the horn works, no abs light on the dash, and all other steering wheel controls work, is it still possible to be a bad clockspring? #3) if it's electrical, where do I start looking?
#8 |
so I took it to the dealership and they said it was 90% the clockspring, 10% maybe not?? And of course they want 900 buck to change all my fluids while its in there
hahaha....whatever!!! Anyone know where to get a replacement clockspring?? stealership wanted 366.00
#9 | ||
Universal Cereal Bus
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler |
#10 |
#11 |
so here's an update. Replaced the clockspring with one from Jeepsareus and same exact problem. Ripped the dash apart to look for a faulty wire somewhere but nothing?? Replaced both switches in the steering wheel and the cc servo, and same problem. It works sometimes and other times no light at all?? It looks like it coming down to the PCM possibly??? Any other ideas??
thanks
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
