Junkyard scores / part compatibility - JeepForum.com
post #1 of 2 Old 10-23-2008, 01:41 PM Thread Starter
psx
1997 XJ Cherokee
I've been trying to search but not having much luck finding what I'm looking for.
Does anyone know of (or wish to help start) a list of compatible parts that we can score off of the ZJ's or other cars sitting in the local junkyard? There are a handful of yards here locally and I'm wondering what can be 'upgraded' by swapping to stock parts from other vehicles.
If we can stick to the below format, I'll do my best to compile it all into one list here at the top. So for starters (any errors or addtl. info, let me know!):
Part: Front Coil Springs
Source: ZJ
years: unknown
Part #: unknown
Reason to use: Cheap 1"(?) lift in front
Part: Seats
Source: ZJ
years: unknown
Part #: unknown
Reason to use: more comfortable
Notes: little bit bigger back seat, some trimming required(?)
Part: Rear disc brakes
Source: ZJ
years: unknown
Part #: unknown
Reason to use: Discs outperform drums
Part: Tie rod & ends
Source: ZJ v8
years: unknown
Part #: unknown
Reason to use: a lot stronger
psx is offline
post #2 of 2 Old 10-23-2008, 02:14 PM
1RustyXJ
Tie rod from a V-8 ZJ works great. A lot stronger and a direct fit(just need to replace the XJ tie rod end with a ZJ tie rod end)
Jeeps are built, not bought.
1RustyXJ is offline
Body part compatibility questions KF4SQB XJ Cherokee Technical Forum 2 12-11-2009 07:21 PM
RTI scores... tdogg55555 XJ/MJ Cherokee Non-Technical Forum 7 08-21-2008 01:19 PM
'88 to '93 part compatibility 4Bngr5Spd XJ Cherokee Technical Forum 3 03-30-2006 02:51 PM
RTI scores, 750 here. What are yours? BeJay1981 XJ Cherokee Technical Forum 7 05-22-2004 06:01 PM
Whats the best Jeep part you got from a Junkyard? Ckwake135 XJ Cherokee Technical Forum 6 05-04-2003 12:22 PM
