junkyard parts run - JeepForum.com
post #1 of 6 Old 03-20-2009, 05:55 AM Thread Starter
gregamuffin
junkyard parts run
doing a parts run this weekend for my 3 inch BB so im getting s10 packs to build bastard packs and zj springs for a v8 zj. i already have 2 inch spacers for the coils and jk takeoff shocks. do i have everything i need? or am i forgetting something?
gregamuffin is offline
post #2 of 6 Old 03-20-2009, 06:10 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Only other thing I would suggest is buying a new rear brakeline for a 95 wrangler. It will be 3" longer than your stock line and a direct bolt on replacement.
xjfever is offline
post #3 of 6 Old 03-20-2009, 07:45 AM
jeepestate
Im thinkn youll need new u-bolts, center spring bolts, and have a plan cause all you rear upper shock bolts will snap off in the body almost gaurnateed.
99 Black XJ, 31" BFG ATs, RE 3.5 SR, JK shocks w/ IRO BPE, IRO Double Shear Track-bar, IRO t-case drop, ZJ HD tie-rod, Pro-comp stabilizer, RC armor
CT JEEP MEMBER #31
Originally Posted by Lupitaboy View Post
You may very well be overqualified to change out your O2 sensor.
jeepestate is offline
post #4 of 6 Old 03-20-2009, 08:24 AM Thread Starter
gregamuffin
so also need to get new hardware and that new brake line. anything else?
post #5 of 6 Old 03-20-2009, 09:04 AM
Ben
you're probably going to want longer end links.
you'll probably have to buy them new or on the boards though.
if you do the new extended brake lines, you might as well replace the hard line from the master cylinder too. FWIW.
Ben is offline
post #6 of 6 Old 03-20-2009, 06:01 PM Thread Starter
gregamuffin
longer end links? even for just 3 inches?
Budget Builds: What junkyard parts will fit an XJ? RedZeppelinXJ XJ Cherokee Technical Forum 708 06-20-2016 04:20 PM
My junkyard lift parts list ShantasticZJ XJ Cherokee Technical Forum 16 03-07-2009 07:28 AM
Any way to do a SYE kit from junkyard parts??? 93ZJbeast XJ Cherokee Technical Forum 9 05-20-2008 05:20 PM
junkyard parts xjfever XJ Cherokee Technical Forum 1 04-13-2008 08:27 PM
