Junkyard lift - JeepForum.com
post #1 of 9 Old 04-30-2010, 01:45 PM Thread Starter
Dereck_408
Junkyard lift
Ok, I am planning to do a junkyard 3" lift on my 96 xj sport.
I plan on making bastard packs using s10 leafs, But i am stuck with what to do on the front.
I may have over looked it but i tried searchin the forum for info on a xj-zj swap but keep getting lost.
Will jus swapping for v8 zj springs give me 3"? or is there another way?
Also what year springs should i look for?
O and my goal is to keep this lift under $200.
Thanks in advance.
Dereck_408 is offline
post #2 of 9 Old 04-30-2010, 02:33 PM
USMC_XJ
2003 WJ
No, the V8 ZJ springs will not net you 3". I have heard of between 1-1.75''. What I did, when I went from stock to 3'', I used a Dakota pack and used ZJ springs with a 2'' spacer. (Really 1.75'' spacer). I bought mine from Summit Racing for $30 for the pair.
Oh, and this is a good write-up to follow. It also gives you good info on cheap shocks.
http://www.rocklizardfabrications.co...dget_boost.htm
Hope this helps.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #3 of 9 Old 04-30-2010, 02:39 PM Thread Starter
Dereck_408
if you dont mind me asking how did you do the dakota pack, and what year? Basically im just wondering what leafs you used out of it and the order.\
Thank you
post #4 of 9 Old 04-30-2010, 02:45 PM
USMC_XJ
2003 WJ
I pulled mine from a 92 Dakota. 2WD. They are the same from 87-95 I believe. They contained a main leaf, second leaf, third leaf, and an overload/helper spring.
What I did was used:
XJ main
Dakota main w/ eyes cut off
Dakota second
Dakota third.
This netted me about 4.25.
With the Overload helper spring in, I got over 5, but that was too much at the time. You can mix and match your XJ and S10 to get the perfect height.
And don't worry, I had plenty of questions. Ask away.
USMC_XJ is offline
post #5 of 9 Old 04-30-2010, 02:48 PM Thread Starter
Dereck_408
I've heard of people Going with the addition of jus the main from the other pack. How high would that bring me?
post #6 of 9 Old 04-30-2010, 02:51 PM
USMC_XJ
2003 WJ
I haven't done this, but I would assume around 2''. Maybe a little more.
USMC_XJ is offline
post #7 of 9 Old 04-30-2010, 02:53 PM
USMC_XJ
2003 WJ
I have a PDF of a write up that some guy did a while back. I have no idea how to put it on here though.
USMC_XJ is offline
post #8 of 9 Old 04-30-2010, 02:57 PM Thread Starter
Dereck_408
If you would like to You can attach it to an email and send it to me. i will pm you my email. Thanks
post #9 of 9 Old 04-30-2010, 06:23 PM
talentjeep
1987 XJ Cherokee
http://www.jeepforum.com/forum/f11/b...fit-xj-847303/
for reference. it gives the spring stats. you can use thunderbird ones too but you need the coil buckets...imo, you should just spend the $100-$130 and buy brand new coils up front. spacers are hokey and if you're going to put a bumper on it you can get beefier springs (for the $100-$130) from RC or Rusty's or wherever....
and i believe this is the bastard pack PDF he was referring to:
http://webpages.charter.net/laurajef...0_pack_PDF.pdf
'87 XJ Pioneer with 32" KM2s, etc.
talentjeep is offline
cheap , junkyard , lift , under $200 , xj-zj swap
XJ Junkyard Lift? taylorC XJ Cherokee Technical Forum 8 10-06-2016 07:49 PM
90 xj, need info on junkyard lift to fit 33" cnmcalpi XJ Cherokee Technical Forum 1 12-25-2009 02:16 PM
is this junkyard lift legit? camxxxl XJ Cherokee Technical Forum 11 09-01-2009 08:01 AM
Junkyard 4.5" lift 1fineXJ XJ Cherokee Technical Forum 1 10-07-2008 09:54 PM
Junkyard springs to lift randol XJ Cherokee Technical Forum 1 04-26-2008 10:41 PM
