Quantcast Junkyard headlight harness? - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Junkyard headlight harness?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.com
Old 11-20-2009, 03:07 PM   #1
keepishop
keepishop's Avatar
1989 XJ Cherokee
Has anyone upgraded their headlight harness by using a junkyard one? It seems an old full size chevy or ford would likely provide a decent upgrade over the xj harness, unless corrosion is an issue. Just throwing that out there...
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline   Reply With Quote
Old 11-20-2009, 04:33 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
You can piece togther a upgraded harness that will use relays that would be better. Look at the upgraded headlight threads and there are links to the DIY HD harnesses.
I went that route and never looked back. Still running strong years later.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 11-20-2009, 05:03 PM   #3
justanotherjpr
The eAutoworks.com harness is $18, including the relays. IMO, not really worth the time to pull a JY harness when you can make or buy one so cheap. FWIW, my eAutoworks.com harness has been in for around 6 months and works great.
justanotherjpr is offline   Reply With Quote
Old 11-20-2009, 05:20 PM   #4
keepishop
keepishop's Avatar
1989 XJ Cherokee
It's just an idea I was kicking around. It would be easy to connect the xj relays to the relays of a batter harness, so it's a dirt cheap option with minimal effort.
Bleed or Quit.
Old 11-20-2009, 05:23 PM   #5
99Greenmachine
I had a friend tell me the other day that a cadillac harness was a direct swap to the XJ.... this is not confirmed though
'99 XJ Sport MY BUILD
Thank You Hooligan!!!
XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA!
99Greenmachine is offline   Reply With Quote
Old 11-20-2009, 05:25 PM   #6
keepishop
keepishop's Avatar
1989 XJ Cherokee
We have a make, do we have a year and a model?
Bleed or Quit.
Old 11-20-2009, 05:25 PM   #7
hubs97xj
1997 XJ Cherokee
Any factory lighting is going to have the same weaknesses as ours- age, small wiring, and circuitous routing. They sell upgraded harnesses to the truck guys as well, for the same reasons.
hubs97xj is offline   Reply With Quote
Old 11-20-2009, 07:45 PM   #8
Carves
Carves's Avatar
TJ wiring is slightly heavier gauge wiring .... slightly
Upgrade looms are as cheap as chips in the states ... not worth bothering with junkyard parts imho.
The 3 pin headlight connections on a jeep are no different to any other brand vehicle ... so the upgrade kits are easy any way.
Carves is offline   Reply With Quote
Glock Forum
