jumped xj=dead xj =( - Page 2 - JeepForum.com
post #16 of 25 Old 02-14-2011, 10:09 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
YEEEEEEEEEHAAAAAAAAAAAAAAAWWWWW!
xjfever is offline
post #17 of 25 Old 02-14-2011, 02:12 PM Thread Starter
truckntractorhi
yea ill check it now. but as of now i have no fuel at the test port on the rail and no spark wont even start with starter fluid! is my ECM gone or something??
truckntractorhi is offline
post #18 of 25 Old 02-14-2011, 03:30 PM Thread Starter
truckntractorhi
*correction/update
fuel is good! so pump and all seam to be working. i checked all grounds and they read good. now im moving into the distributer/ignition system. possible cam sensor?
p.s. still no voltage or gas gauges.......
post #19 of 25 Old 02-14-2011, 05:19 PM
Carves
Originally Posted by truckntractorhi View Post
*correction/update
Give the dash gauge panel a thumping in case its the common issue of the connectors at the back .....
Probably should remove it and give it a dose of dialectric grease anyway
Carves is offline
post #20 of 25 Old 02-14-2011, 06:30 PM Thread Starter
truckntractorhi
but the self diagnostic test works! (turn it to "on" while holding in trip reset button)
post #21 of 25 Old 02-14-2011, 06:50 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
That tests the actual gauges for functionality, not their connections.
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline
post #22 of 25 Old 02-14-2011, 06:53 PM
mjjeeper
1988 MJ Comanche
Originally Posted by mike_breaker_5 View Post
well to make light of the situation... i read the "HIGHLIGHTS" from the thread so far to my wife as proof that i am not the only one to do dump stuff in their jeep. i am referring to the time we were all out for a trail ride, me the pregnant wife and our 2 year old in a car seat in the back of the yj. i drove into the creek and the crossing had washed out on the bottom and there we sat, in water coming over the half doors. needless to say she was less than impressed. a $500 salvage motor and a weekend of work i had the jeep back on the road. she has not gone for a ride with me since. this was almost 2 years ago.
sorry to have no pertinent info to add to your diagnosis i just wanted to let you know i laughed very hard.
Your supposed to know the terrain BEFORE you take the wife out. That way nothing happens and you look like an expert. lol
mjjeeper is offline
post #23 of 25 Old 02-14-2011, 06:54 PM
Carves
Was just a thought ....
As an aside ..... Im pretty sure that you could have the gauges sitting on the living room floor and the self-test would work as long as you fed it 12v.
ACTUATOR TEST
The instrument cluster actuator test will put the cluster into its self- diagnostic mode. In this mode the cluster will position each of the gauge needles at various specified calibration points, and turn all of the
CCD data bus message-controlled lamps on and off at specified time intervals (Fig. 1) or (Fig. 2).
Successful completion of the actuator test will confirm that the cluster circuitry, gauges, and lamps are capable of operating as designed. However, there may still be a problem with the CCD data bus, the Powertrain
Control Module (PCM), the Airbag Control Module (ACM), or the inputs to one of these modules.
You have been through the fuseboxes and tested/swapped over ... all relevant fuses & relays ???
Carves is offline
post #24 of 25 Old 02-14-2011, 06:59 PM
mike_breaker_5
i had been through that crossing just days earlier (and dozens of times before that). like i said the bottom had washed out. what should have been a tire rinse turned into a tow home.
Ratmonkey donation page. all proceeds will go to his family.
http://www.youcaring.com/memorial-fu..._source=widget
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
http://www.jeepforum.com/forum/f22/m...r-junk-990191/
mike_breaker_5 is offline
post #25 of 25 Old 02-14-2011, 09:22 PM Thread Starter
truckntractorhi
ACTUATOR TEST
yes all has been checked! could it be something in the cam sensor? idk my DD is down
Compressor only comes on when jumped? RamboPants XJ Cherokee Technical Forum 8 08-01-2009 11:47 AM
i jumped the jeep ken_swift302 XJ/MJ Cherokee Non-Technical Forum 20 01-29-2009 01:24 PM
i jumped ship freeburg MJ Comanche Technical Forum 8 05-05-2007 08:42 PM
Here's how I jumped 6 MPG on one tank. 88XJSport XJ Cherokee Technical Forum 8 10-06-2006 05:48 AM
Won't start unless jumped - sometimes Neuner XJ Cherokee Technical Forum 8 02-17-2005 09:37 PM
