jumped xj=dead xj =( - JeepForum.com
post #1 of 25 Old 02-12-2011, 05:07 PM Thread Starter
truckntractorhi
well i was driving along and i jumped the xj going about 60ish... upon takeoff the rear bottomed out (dang old leafs) and it flat out cut off. dead, nothing! my guess would be the fuel pump connector that is above the rear axle pumpkin so ill try to wire that in or something....... any thoughts?
truckntractorhi is offline
post #2 of 25 Old 02-12-2011, 05:10 PM
gonejeepin04220
1995 XJ Cherokee
jeeps require you always keep atleast two wheels on the ground
95 xj,5 speed,
5" lift, 33 12.5 dessert dogs
chrysler 8.25,
"my xj is so horny, sometimes im scared itll came right up in a wheelie"
gonejeepin04220 is offline
post #3 of 25 Old 02-12-2011, 05:24 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Does the fuel pump run?
When you turn the key to the ON position, the pump should energize and run for approximately 2 seconds.
Does it do that? If it doesn't, then yes....concentrate on the fuel pump, AND its control electronics.
But the pump does energize properly, then you should pull a spark plug and check for SPARK, as it may not be fuel related.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 25 Old 02-12-2011, 05:32 PM Thread Starter
truckntractorhi
ok well i just went out and pulled a plug and volla! no spark while cranking. what are my options now?
post #5 of 25 Old 02-12-2011, 05:42 PM
Carves
...... any thoughts
You're blaming the poor little, all wheel drive, station wagons rear suspension .....
.......... For not getting you successfully recognised as orvilles and wilburs long lost, little brother ????????
X 2 with tjwalker on checking the pump & wiring ... Ive had issues just with bottoming out on lumpy roads in the TJ & XJ.
After that its a matter of checking all connectors, relays etc to ensure positive mating of connections.
Maybe you even cracked the coil ????
Carves is offline
post #6 of 25 Old 02-12-2011, 05:47 PM
tjwalker
tjwalker's Avatar
Test your crankshaft position sensor. The "Dukes of Hazzards" jump may have taken it out.
Test your ignition coil.
Check all fuses.
tjwalker is offline
post #7 of 25 Old 02-12-2011, 05:53 PM Thread Starter
truckntractorhi
hahaha hey my right foot got a little horny ok? but do you have a link for testing the ignition coil? im looking here:http://www.jeepforum.com/forum/f11/9...s-good-905398/ for CPS info. but idk if its different cause i have a manual? anyhow...... suspense! =P
post #8 of 25 Old 02-12-2011, 05:56 PM
tjwalker
tjwalker's Avatar
Don't have a link to a procedure for the coil. They need to be tested for primary and secondary resistances and there are specific high/low numbers.
Spring for a manual and you'll have that procedure and a good reference book for your future aerobatics!
tjwalker is offline
post #9 of 25 Old 02-12-2011, 09:25 PM Thread Starter
truckntractorhi
ok ill look it over in my repair manual.... man i forget to think sometimes! i also would like to add i have no gas or voltmeter readings. i am 100% sure they worked before..... that points to a CPS! could it be another thing other than that? the jeep has 214K and its suppose to be changed every 100K give or take.
post #10 of 25 Old 02-13-2011, 06:51 AM
tjwalker
tjwalker's Avatar
Good additional advice as it provides a very important clue.
When the crank sensor fails a certain way, you can lose both the gas gauge and the voltmeter.
So yes, you are correct in that this points DIRECTLY to the crank sensor.
You can test the crank sensor if you like; my money is on this component all the way.
I buy my crank sensors directly from Jeep as I have had mixed (poor) luck with certain aftermarket sensors. Worth the extra money in reliability.
tjwalker is offline
post #11 of 25 Old 02-13-2011, 07:53 AM
Cherokee-at-16
Heres a good question.....WHY ISN'T THIS ON VIDEO???????
2000 Cherokee Sport Build: http://www.jeepforum.com/forum/f22/2000-xj-build-slow-uneventful-1162913/
Cherokee-at-16 is offline
post #12 of 25 Old 02-13-2011, 08:12 AM
mike_breaker_5
well to make light of the situation... i read the "HIGHLIGHTS" from the thread so far to my wife as proof that i am not the only one to do dump stuff in their jeep. i am referring to the time we were all out for a trail ride, me the pregnant wife and our 2 year old in a car seat in the back of the yj. i drove into the creek and the crossing had washed out on the bottom and there we sat, in water coming over the half doors. needless to say she was less than impressed. a $500 salvage motor and a weekend of work i had the jeep back on the road. she has not gone for a ride with me since. this was almost 2 years ago.
sorry to have no pertinent info to add to your diagnosis i just wanted to let you know i laughed very hard.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #13 of 25 Old 02-13-2011, 05:17 PM Thread Starter
truckntractorhi
well i put in a new CPS and nothing still no voltmeter or gas gauges...... could the ECM be gone?
post #14 of 25 Old 02-13-2011, 06:24 PM Thread Starter
truckntractorhi
post #15 of 25 Old 02-14-2011, 10:58 AM
unkajeffy
Check your battery and grounds, and all your plugs to your ECM you might have shook everything loose when landing on the non regulated airfield. If nothing else works review the Flight Data Recorder information. I would also make sure all the relays are properly seated.
Michigan Yankee in Redneck Land
unkajeffy is offline
Compressor only comes on when jumped? RamboPants XJ Cherokee Technical Forum 8 08-01-2009 12:47 PM
i jumped the jeep ken_swift302 XJ/MJ Cherokee Non-Technical Forum 20 01-29-2009 02:24 PM
i jumped ship freeburg MJ Comanche Technical Forum 8 05-05-2007 09:42 PM
Here's how I jumped 6 MPG on one tank. 88XJSport XJ Cherokee Technical Forum 8 10-06-2006 06:48 AM
Won't start unless jumped - sometimes Neuner XJ Cherokee Technical Forum 8 02-17-2005 10:37 PM
