July 2007 C.O.M. **Modified Class** vote here
| View Poll Results: vote for the July 2007 Cherokee of the Month **Modified Class** | |||
| cherokeewes |
22 | 15.07% |
| 12 Volt Man |
43 | 29.45% |
| xj-Jen |
17 | 11.64% |
| LEAD_NOT_FOLLOW |
57 | 39.04% |
| TwistedSymphony |
7 | 4.79% |
| Voters: 146. You may not vote on this poll | |||
#1 | |
The Post man
Entry #1
cherokeewes 2000 cherokee classic 4.0 aw4 np231 rock krawler 8 inch long arm lift and x-factor steering with skyjacker shocks 35x14.5" boggers on ar 737 with 4 " bs dana 30 richmond 4.88's and detroit trutrac ford 8.8 richmond 4.88's and lockrite 2 cowl mounted kc dayliters and roof mounted hilift doorless mod and a lot of trimming flowmaster 40 cat back and k&n cone filter 100w vhf radio and 100w pa and siren re hack n tap and cv ds ![]() ![]() Entry #2 12 Volt Man 2000 XJ Sport Rubicon Express 4.5 inch Super Flex Lift 33x12.50 BFG All Terrain KO's Bushwhacker Fender Flares Rubicon Express Gen 2 discos Custom Fab Rear Tire Carrier Expedition One Front Winch Bumper Super Winch EPi9 w/synthetic line Hella 500 lights D30/Chryco 8.25 4.56 Gears w/Detroit Soft Lockers front and rear Magnaflow Exhaust Custom Rock Sliders Bedlined Rockers Ruffstuff Specialties 3/8" Diff Covers Rear ZJ Disc Brake Conversion ![]() ![]() Entry #3 xj-Jen 92 Limited tnt customs 5.5 y-link 33x12.5 Goodyear mtr's ProComp Xtreme alloys 1069 Bushwacker fender flares front: superior super d30, tnt truss rear: superior super d44, tnt truss arb's front and rear 4:56 gears ORO U turn cross over steering jks quicker disconnects tnt frame stiffeners jks steering box brace wj dual diaphragm brake booster jks rear shock hoop Heavy duty Borgeson Steering shaft Bilstein 12" 5150's ![]() ![]() Entry #4 LEAD_NOT_FOLLOW 1989 Cherokee Laredo Motor Golen 4.6L Stroker 9:1 Compression Ratio. Redline right under 6K. Block: Thermally cleaned and Stainless Steel Shot. Inspected by MPI process. Decked, bored, honed with torque-plates and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed. Crank: Peformance ground 4.2L crankshaft, micro polished and oil holes chamfered. Rods: Jeep steel rods, shot peened for strength, resized with new performance rod bolts. Pistons: Speed-Pro hypereutectic. Rings: Speed Pro Plasma-Moly. Bearings: Clevite Main and Rod Bearings. Core Plugs: Brass Pioneer core plugs. Lifters: Comp Cams Hydraulic. Pushrods: Comp Cams. Rocker Arms: Comp Cams. Timing Set: Dynagear Performance. Cams: Comp Cams. (duration) - Intake: 218˚@ .050˚ Exhaust: 226˚@ .050˚ (lift) - Intake: .493˚ Exhaust: .512˚ (seperation) - 111˚ Oil Delivery: Melling high volume pump, pickup tube and HD Drive Gasket Set: Fel-Pro Performance Head Bolts: SBI Performance Head: '95 HO Head. Combustion Chamber: 62cc - Intake Runner: 155 cc. Three angle valve job, bowl ported, valves back cut, new guides etc. Exhaust: Custom Header/Downpipe/Exhuast Engine Management: Motec Cooling: Hesco High Flow Waterpump, CSF 3 Core Radiator, Hesco High-Flow T-stat Housing, BRX Hoses, Mr. Gasket High-Performance T-stat. I'm at aprox 290HP @ 5000rpm and 330ft/lbs @ 4000rpm. Kenne Bell Supercharger in the works... Drivetrain/Axels AW4 w/switch shift mod NP231 1" TC Drop Dana 30 Front w/Detroit Locker Dana 44 Rear Lift/Tires 5” Hybrid Lift RE Superflex Adjustable Upper and Lower Control Arms RE 3.5” Rear Leafs RE 1.5” Boomerang Rear Shackles RC Front Springs OME Shocks RE Gen. 2 Quick Disco’s Motion Offroad Tie Rod w/Flip Kit 35” Maxxis Bighorns 15” Crager Streetlocks Exterior Motion Offroad Rock Crawler Front Bumper Custom Rock Rails LaBarron Hood Vents ARB Safari Snorkel Rear Quarter Guards Metal Taillights w/Led’s Removed Flares Bedlined Rockers Con-Fer Roof Rack Removable Doors Yakima Powederhound Ski/Board Holder IPF Front Headlights 6 Fog lights (2 on bumper, 4 on rack) Recovery Custom 4X4 Tow Hooks 48" Hi-Lift Jack Axe/Shovel Rear Hitch Gas Tank Skid DPG Belly Skid Motion Offroad C02 Airtank 30ft Strap w/D-rings Interior Eagle Journey GPS w/6" screen Cobra WX 40Chn. CB w/4ft Firestick Beartracker SAR Radio/Scanner Dell Laptop w/Custom Laptop Mount Alpine CD Headunit 800watt Amp w/2 12" Kenwood Subs Custom 7 switch panel Whellen Dash Strobes Whellen Rear Strobe Bar Whellen Corner Strobes (use the vehicle for SAR) ![]() Entry #5 TwistedSymphony 1988 MJ long wheel base 4.0, AW4, NP231 Lift--- 6.5" Skyjacker coils Teraflex adjusteable LCAs Rustys adjustable UCAs Teraflex adjustable tracbar SOA rear with 2" XJ lift shackles Tires/Wheels-- 34x9.50x15 TSLs CJ rims with 5x4.5 to 5x5.5 adapters/spacers Axles-- Stock D44 rear HP D30 with 297x 1-piece shafts Accessories-- C4X4 front hooks Custom built rear bumper with 2" reciever Custom built gas tank skid plate Custom built transfercase skid plate ![]() ![]()
#2 |
The Guru of Nothing
lead you got my vote, i would have voted for cherokeewes but there werent any action picks
-Kyle
North Bay, CA Jeepers Post Here My Build Thread ~My Write Ups~ It's Not Just a Jeep, It's a Lifestyle
#3 |
12VoltMan, is that a photochop in the second pick?
Mine: 2000 Black XJ Sport, D30 and 8.25 w/ Yukon 4.56's, 4.5" RE SF (plus a 1.75" Daystar spacer, 1.75" Teraflex shackle), OME LT Shocks, SJ SS, M.O.R.E Steering Box Brace, JKS Adj Track Bar, JKS Discos, AA SYE and TW CV DS, 15x8 Black Rock Krawlers, 33x12.5x15 Maxxis Bighorns, Bushwackers, ARB Bumper, 45 x 60 Surco rack, AJ's Super Rails, Class III rear hitch, 4 100w Hella 500's, Hella 550s, Hella Vision Plus, CB w/4ft Antenna, removable hood deck port, Borla cat back etc. |
#4 |
I did crop and lighten things a little in photoshop. Other than that nothing is photoshopped. What is it that looks photoshopped?
On a side note..... just my luck to enter in the same month as an XJ with a nice stroker. Very nice rig LEAD_NOT_FOLLOW.
[B]2000 XJ Sport,[/B] [COLOR=Red]Red[/COLOR] 115k 4.5 inch Rubicon Express Lift, [COLOR=Red]Red[/COLOR] Bushwhackers, D30 and 8.25 w/Detroits 33 x 12.5 BFG A/T's Magna Flow Exaust [COLOR="Lime"][FONT="Comic Sans MS"]Parrothead Jeepers Union, member #23[/FONT][/COLOR] |
#5 |
Lead good luck mang
but for everyone else VERY NICE JEEPS THIS MONTH |
#6 |
I picked a bad month to enter
![]() I voted for LEAD. Its hard to beat that rig.
1988 MJ 4.0/D60/14b/5.38/42s/PSC hydro 1995 XJ 4.0/AW4/231/JCR sliders/235s on KJ 16" wheels 1995 F250 PSD/33 BFG ATs/HP D60/Edge Evolution |
#7 | |
#8 | |
#9 | |
#10 |
Wow, very tough decision, Lead not follow got it. All of em' are very nice but that is one stout rig. keep up the good work.
I hope one day I can build a rig anything like any one of these. Just got a job, so I am gonna start with a BB in the very near future. ![]()
Eagle Scout Club Member #2 Silver Cherokee |
#11 |
Here is the original before changing the lightness etc...
#12 |
12volt's rig is soooooooooooooooooo awesome looking. But I can't pick looks over a stroker. All very nice rigs, though
#13 |
Lots of nice rigs everyone!
Jennifer
[COLOR=DarkGreen][FONT=Impact]1992 Cherokee Limited[/FONT][/COLOR] [FONT=Impact][COLOR=DarkGreen]TnT Y-Link, 33"MTR's, d44, d30, 4.56, ARB's [/COLOR] [/FONT] |
#14 |
whoot comanche!!!
'87 YJ, Spring over w/ 2" springs, SYE, 4.88's, Locked Dana 44 front, Toyota 8" rear w/ factory E-Locker, 36" swampers, sliders, bumpers, caged, dented & scratched |
#15 | |
Either way it looks great and I was not trying to start controversy. ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
