JKS Diconnects Problem - JeepForum.com
post #1 of 7 Old 06-26-2013, 09:15 PM Thread Starter
mhouser2
Hey guys so I got my Cherokee probably around 3 months ago and when I got around to wheelin it for the first time I went to unhook my disconnects and my passenger side disconnect wont come off because there's not enough clearance between it and the steering stabilizer bracket. I was wondering if any of you guys have seen this before and seen why it's happened and an easy fix for it. I would rather not grind it down but if that's all I got then that's what I'll do.
mhouser2 is offline
post #2 of 7 Old 06-26-2013, 09:54 PM
tinktinkTJ
The first thing I would do is bend the bracket that holds the sway bar disco away from the SS. A BFH or a pry bar should do the trick.
tinktinkTJ is offline
post #3 of 7 Old 06-26-2013, 10:05 PM Thread Starter
mhouser2
That was my main thought. It looks pretty cocked in so I think I might straighten it up.
mhouser2 is offline
post #4 of 7 Old 06-26-2013, 10:10 PM
tinktinkTJ
I'm 99% sure that will solve the problem. If it doesn't post back in this thread and we can find another solution.
post #5 of 7 Old 06-26-2013, 10:15 PM Thread Starter
mhouser2
Will do I'm gonna try to get to it tomorrow. I'll post how it goes. Appreciate it.
mhouser2 is offline
post #6 of 7 Old 06-27-2013, 02:28 AM
Timo_90xj
Timo_90xj's Avatar
You have a bent swaybar endlink bracket on the axle. Like mentioned, straighten it and you should have no issues.
***Under construction***
Timo_90xj is online now
post #7 of 7 Old 06-27-2013, 07:24 PM Thread Starter
mhouser2
I straightened it up today and I'm back in business. Appreciate it.
mhouser2 is offline
cherokee , disconnects , jks , sway bar
