-   -   JKS Diconnects Problem (http://www.jeepforum.com/forum/f11/jks-diconnects-problem-1541863/)
mhouser2 06-26-2013 10:15 PM
Hey guys so I got my Cherokee probably around 3 months ago and when I got around to wheelin it for the first time I went to unhook my disconnects and my passenger side disconnect wont come off because there's not enough clearance between it and the steering stabilizer bracket. I was wondering if any of you guys have seen this before and seen why it's happened and an easy fix for it. I would rather not grind it down but if that's all I got then that's what I'll do.
http://i1316.photobucket.com/albums/...s8dd37906.jpeg
http://i1316.photobucket.com/albums/...sf2566851.jpeg
http://i1316.photobucket.com/albums/...s92353d8f.jpeg
http://i1316.photobucket.com/albums/...sa30a4d48.jpeg
tinktinkTJ 06-26-2013 10:54 PM
The first thing I would do is bend the bracket that holds the sway bar disco away from the SS. A BFH or a pry bar should do the trick.
mhouser2 06-26-2013 11:05 PM
That was my main thought. It looks pretty cocked in so I think I might straighten it up.
tinktinkTJ 06-26-2013 11:10 PM
I'm 99% sure that will solve the problem. If it doesn't post back in this thread and we can find another solution. :cheers:
mhouser2 06-26-2013 11:15 PM
Will do I'm gonna try to get to it tomorrow. I'll post how it goes. Appreciate it.
Timo_90xj 06-27-2013 03:28 AM
You have a bent swaybar endlink bracket on the axle. Like mentioned, straighten it and you should have no issues.
mhouser2 06-27-2013 08:24 PM
I straightened it up today and I'm back in business. Appreciate it.
The time now is 07:13 PM.
