Jeep XJ weird startup issue - JeepForum.com
post #1 of 5 Old 07-31-2013, 02:25 PM Thread Starter
jmp4x4
1993 XJ Cherokee
Hi to all, im new at this and donīt know much about mechanics, so I think some of you guys can help me with this strange startup issue.
My XJ 93 cranks and it tries to start, but goes off, after the second try it stays on for a few seconds at no more de 500RPM and then goes off, at the third try it goes on for about 20 seconds at less than 500rpm and goes off again, but at the fourth try it goes for about 30 segonds at about 500rpm and then it revs up to about 2000rpm, and then back to a stable 900-1000 rpm for the rest of the day it works fine only at the first try, but when I leave it overnight I always get this problem.
My mechanic has already change the oil pump, fuel regulator, battery, and still donīt know what the problem might be.
Any help will be greatly appreciated, having this problem since I rebuilded my engine, everything else works like a charm after 5 step painfull morning startup.
jmp4x4 is offline
post #2 of 5 Old 07-31-2013, 06:19 PM
psychoteen101
Find out what your mechanic tested and the reason to replace all those parts. Seems like he is just randomly throwing parts into it. Is the check engine light on? Find out if he checked fuel pressure as well as spark.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #3 of 5 Old 07-31-2013, 10:29 PM
MoparMech
1995 XJ Cherokee
IAC Motor possibly. Does it stay running if you put your foot on the throttle?
MoparMech is offline
post #4 of 5 Old 08-01-2013, 12:19 PM Thread Starter
jmp4x4
1993 XJ Cherokee
Thanks for the reply, It also seemed to me that we was just throwing parts, now I already paid for all the parts and the problem still there, He said he checked pressure, and it was ok, he changed the oil pump because it was very very old (true) was at least 50K.
Everything else works fine, after it starts in the morning I can re start the car many times it works perfectly, only after I leave the car overnight I get the problem in the mornings, I live in a dry enviorement all year round between 60F-70F.
As I said before this problem started after I rebuilded my engine, but once the car is on everything works perfectly, and I donīt get engine lights.
jmp4x4 is offline
post #5 of 5 Old 08-01-2013, 12:32 PM Thread Starter
jmp4x4
1993 XJ Cherokee
Hi thanks for your reply, Yes once the car starts after the fifth sometimes fourth attemp it stays on with no problems, runs perfectly no bad symptoms at all, the only problem is the morning starting issue but Iīm afraid this Issue might lead to some other problems. I never press the gas pedal on this initial cranks I always let the injection to work around by itself after several seconds under 500REV you feel the Vroommm to about 2000Rev and back to a steady 900-1000Rev.
Someone told me that the fuel check valve might be leaking fuel back to the tank and thatīs why the car takes three or four cranks to start, I told my mechanic and he said heīd never heard of that before, I live in Colombia South America, and there arenīt many Jeep Shops, my mechanic is one of the biggest and renowend shops in Bogota.
Being having this issue for about 8 months I donīt use the car much, but when I do I always get frustrated on those first cranks after that everything works fine, mechanical and electrical.
I will make a video to show the morning symptons, since my english is not that well, and my knowledge of mechanics is pretty basic.
jmp4x4 is offline
crank , fuel pump , regulator , starting issue
