jeep xj turbo charger, to good to be true? - Page 3 - JeepForum.com
post #31 of 37 Old 04-01-2014, 01:51 AM Thread Starter
hayden93
1993 XJ Cherokee
Originally Posted by sAe23 View Post
??Why do you think your top speed would be so low??
If you are running the 32" tires from your profile, 4.56 gears MIGHT have put you around or under 2500 RPMs at 65MPH in OD.
I went to 4.56 for my 33" tires. At 65MPH in OD the engine turns at 2250 RPM.
I kinda wish I went to 4.88...
what! i actually have 31" tires now, but still it shouldn't make that much of a difference, the guy that installed them looked at me like i was crazy when i told him i wanted 4.56, he said that i would be lucky to hit 65-70mph and thats at 4000rpm... he said 4.10 gears would put me closest to stock! i got a really good deal on the gears and install tho, i was very happy with the outcome tho, it doesnt shift back and forth when im at high speeds on the highway any more.. it feels like it has more torque.
daily driver, if I roll it, im SCREWED!
hayden93 is offline
post #32 of 37 Old 04-02-2014, 04:26 AM
sAe23
1995 XJ Cherokee
4.10's with 31" tires IS close to "stock" (3.55 with 27" tires), but to hit 4000 RPMs with 31" tires you'd need 5.71 gears
The important thing is that you're happy with the results
sAe23 is offline
post #33 of 37 Old 04-02-2014, 04:35 AM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
I have 4.10's with 33's and I run 75 mph at about 2300 rpm's and my Speedo is only off by 3 mph.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #34 of 37 Old 04-02-2014, 07:13 AM
chriskeenan
Originally Posted by hayden93 View Post
would this work...? seems like it does what i need correct? http://www.aemelectronics.com/inline...ontroller-1159
Thats just a wide band O2 sensor and its controller, its used to set up and tune the engine, typically once the tuning is done a standard narrow band O2 sensor are used to run the engine. You still have to tune the engine, a wideband is very helpful with that.
chriskeenan is offline
post #35 of 37 Old 04-03-2014, 02:27 AM Thread Starter
hayden93
1993 XJ Cherokee
ok that makes sense, i think im going to have to sit on the turbo kit a little longer, ill be honest i cant afford anything that expensive right now... once i have all the the parts ill start putting it all together, until then ill keep looking around for something a little more affordable, thanks for all you help guys
hayden93 is offline
post #36 of 37 Old 04-03-2014, 02:35 AM
chriskeenan
Look in to megasquirt. It looks intimidating and cobbled together but it the cheapest option for FI and it's actually pretty well supported. and there is also an auto transmission controller module so you could program the entire drive train with it. You could even run MS parallel with the stock ECU to get the stock jeep gauge cluster to work. MS would handle all the engine stuff and the stock computer just running the gauges.
post #37 of 37 Old 04-03-2014, 04:39 PM Thread Starter
hayden93
1993 XJ Cherokee
after doing a little research i stumbled upon this thread, dude turboed his yj for like $500, this is what he said abut fuel: My turbo is sized really good for the motor, I would say that at normal crusing speed there is no lag at all, and yes it is a home made kit. I was going to intercool it but after thinking about it I opted not to because an intercooler will just take up space and moving a 2 mph on the trail, the IC will not do a thing. Instead I will be running a water/meth injection setup. That way everytime i hit enough boost i will be a nice cool dense air charge. Im running 7psi now, the water/meth will come on a 4psi. no chips or computer mods. just used a 12:1 FMU and a booster pump. jeep pulls really hard actaully and is really nice to drive. Im located in central CT, Newington to be exact. i'll get the numbers up as soon as i get to the dyno
i found the fmu online at a great price... now i just have to find the right booster pump, whats your thoughts on this rout? thanks
hayden93 is offline
cheap , turbo
