jeep xj turbo charger, to good to be true? - JeepForum.com
post #1 of 37 Old 09-11-2013, 01:14 PM Thread Starter
hayden93
1993 XJ Cherokee
been looking for a turbo charger for my 93 xj for a while. was browsing on ebay today and found this, what parts am I also going to have to buy and do you think this will work?
the seller has awesome feedback but like I said, it just seems to good to be true!
http://www.ebay.com/itm/T3-T4-Turboc...1cd2ed&vxp=mtr
hayden93 is offline
post #2 of 37 Old 09-11-2013, 01:20 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to Cherokee Tech Forum.
The forum you posted in (JeepForum Announcements & Comments) is for questions about and help with the forum.
Wheelin98TJ is offline
post #3 of 37 Old 09-11-2013, 01:54 PM Thread Starter
hayden93
1993 XJ Cherokee
ooops sorry , im new to this forum thing, thanks for stearing me in the right direction!
daily driver, if I roll it, im SCREWED!
hayden93 is offline
post #4 of 37 Old 09-11-2013, 01:57 PM
LimeLJ
LimeLJ's Avatar
That is just a basic universal kit that the seller then spams across eBay tagged that it "fits" all these different vehicles. There will still be significant fabrication required to install it and then the required electronics to handle boost.
2004 Jeep Wrangler Unlimited
1997 Jeep Comanche - 4.7L Stroker, Lifted, "Restored", and soon to be supercharged.
LimeLJ is offline
post #5 of 37 Old 09-11-2013, 02:09 PM Thread Starter
hayden93
1993 XJ Cherokee
[QUOTE=LimeLJ;15911441]That is just a basic universal kit that the seller then spams across eBay tagged that it "fits" all these different vehicles. There will still be significant fabrication required to install it and then the required electronics to handle boost.[/QUOTE
too good to be true... I KNEW IT!
thanks for your input.
hayden93 is offline
post #6 of 37 Old 09-11-2013, 02:13 PM Thread Starter
hayden93
1993 XJ Cherokee
does anyone know what i would need to make this a complete and fully working/ installable kit?
im only trying to get about 4psi, just to get me up those highways on my way to trails.
thanks
hayden93 is offline
post #7 of 37 Old 09-11-2013, 02:47 PM
chriskeenan
thanks
Why do you feel the need to turbo the engine? if youre having power issues with larger tires then change the gearing. If you have the correct gears and just want more power, why not stroke it or swap in a V8.
But to answer your question; a lot. You'll still need the exhaust manifold fabricated = $$$. You'll need an intercooler, and to make the IC fit somewhere. The whole intake and IC piping needs to be fabricated as well. on top of that the stock ecu wont work, so now youre looking at a stand alone unit, which is $$$, or screwing around modifying sensor inputs to make the stock one work, which if you do wrong can destroy the engine.
Id also bet the included turbo is junk, i doubt its a real garrett unit, and for that price if it is real its worn out.
chriskeenan is offline
post #8 of 37 Old 09-11-2013, 02:51 PM Thread Starter
hayden93
1993 XJ Cherokee
ive been doing a little research myself in the last hour... maybe ill just change the gears lol
hayden93 is offline
post #9 of 37 Old 09-11-2013, 02:56 PM
wgirvine
1992 XJ Cherokee
Nothing to it... some radiator hose, some duct tape, make an intake outta PVC, coupla hose clamps... you're all set.
The road goes on forever, the party never ends....
wgirvine is offline
post #10 of 37 Old 09-11-2013, 03:12 PM Thread Starter
hayden93
1993 XJ Cherokee
lol i already have a cold air intake on it , and that didn't seem to make much difference either.
hayden93 is offline
post #11 of 37 Old 09-11-2013, 06:10 PM
sAe23
1995 XJ Cherokee
You could throw a supercharger on it. Only a few grand
sAe23 is offline
post #12 of 37 Old 09-11-2013, 07:48 PM
AZ Jeff
2014 JK Wrangler
Smart-assed commments from others aside, there is no "free lunch" with a turbocharger. You will generate more heat, more load on the crank bearings, and thus shorten the life of your engine.
For the money that a proper turbo costs, and MUCH better solution is a stroker engine. It's more durable, and less complicated.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #13 of 37 Old 09-12-2013, 10:08 AM
foggybottombob
From someone who spent a lot money building a stroker, the only sane way to add power to any 6 cylinder powered vehicle is to swap in a V8. If you do anything to an engine in an XJ to significantly increase horse power you will need an aluminum radiator to cool it. The factory cooling system is barely adequate for the stock engine. My stroker runs fine but I'm sure a regular V8 would be better if you could make one fit in an XJ.
foggybottombob is offline
post #14 of 37 Old 09-12-2013, 10:49 AM
CCKen
CCKen's Avatar
CCKen is offline
post #15 of 37 Old 11-23-2013, 07:24 AM
CobraMarty
Tuning can be a problem and expensive with the stroker.
Stay with the 4.0L and supercharge it.
I have 2 XJs with 4.0 150k+miles and both are supercharged.
Can be done for about $2k. Done in 1 day. Adds +60rwhp and +80rwtq. Smog/OBD2 legal. Click on my sig. There is a lot of info there including dyno results of many different combinations.
'98 XJ AW4 4.0 SUPERCHARGED M90 225+HP
Jeep M62/90 XJ TJ JK Supercharger Expert, PM any Questions
CobraMarty is offline
cheap , turbo
