Jeep XJ 1996 Auxiliary Fan Temp Sensor ? - JeepForum.com
post #1 of 11 Old 06-30-2009, 09:45 AM Thread Starter
blackrain
My Jeep runs hot when idling on a hot day or when I'm pulling the boat. I feel my auxiliary fan turns on too late because it starts spinning at 220F. The fan however turns on regardless at any temp when I run the AC.
Should I replace the temperature sensor that turns on this fan or some actuator in the control unit? Where is it? Help?
I have also done a coolant flush and installed a 190F thermostat.
blackrain is offline
post #2 of 11 Old 06-30-2009, 09:49 AM
XJdamyankee
Well your fan is running normal, it's not suppose to come on until you hit 220 or whenever you turn the ac on. Your other options would be to put in an override switch for the fan so you can turn it on anytime plus if your pulling a boat I would strongly suggest you upgrade your radiator and install a trans cooler.
96 cherkoee SE I-6 AW-4 np231 dana30/chrys 8.25
Doug Thorley Tri-Y header/magnaflow cat/rustys FM50 exhaust
Kumho KL71's 31x10.5x15 mounted on rock crusher 15x8 w/4.5"BS black D-window
OME 2" lift & shocks, RE super-ride control arms
XJdamyankee is offline
post #3 of 11 Old 06-30-2009, 11:01 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
215-218* is the normal temp for the E-fan to turn on.
If you are running hot you need to focus on the other parts of the cooling system. Is your radiator clogged with mud and bugs outside or mineral deposits on the inside ? Is your mechanical fan clutch working correctly ? How old is your water pump ? The vanes on the water pump can wear down and your coolant flow will be less than required. When was the last time you replaced your radiator cap ? Are your radiator hoses old and mushy and collapsing under pressure enough to restrict the coolant flow ?
Do you have an auxiliary transmission cooler installed as recommend when towing ?
CJ7-Tim is offline
post #4 of 11 Old 06-30-2009, 12:47 PM
DC4W-93XJ
1990 XJ Cherokee
wire that baby to a switch!
THIS AIN'T YOUR MAMA'S STATION WAGON!!
Built Jeep Tough With Chevy Stuff
"Tater 2" '91 2 door XJ chopped and bobbed, 4.0, AW4, dana 300, GM 60/70HD, 40" IROKs on H1s
DC4W-93XJ is offline
post #5 of 11 Old 06-30-2009, 12:57 PM
MJR
MJR's Avatar
1988
Just wire it directly to the fan motor and don't even try to wire it into the relay coil side unless you want to buy a new PCM down the road.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #6 of 11 Old 06-30-2009, 02:03 PM Thread Starter
blackrain
How do I do that. Wire the Fan motor to...? As long as it turns off when the car is off.
I bought my 1996 jeep a year ago. Has 102k on it. Other then a coolant flush and thermostat I have not changed any other cooling components. The radiator looks fine but then again I couldn't get a great look at it because the AC radiator is in the way. I'm hesitant to move it since the AC still works.
post #7 of 11 Old 06-30-2009, 04:01 PM
Goldenknob
2007 WK
you might just need to get a new clutch for your clutch pulley fan. they don't cool as well as they should when they start to wear out.
Goldenknob is offline
post #8 of 11 Old 06-30-2009, 06:03 PM
CJ7-Tim
CJ7-Tim's Avatar
If your cooling system is working properly, you do not need to run the E-fan on a switch.
Service your cooling system, and replace any under-performing parts. Fix it right, and it will work right.
Install a transmission cooler.
CJ7-Tim is offline
post #9 of 11 Old 06-30-2009, 06:44 PM Thread Starter
blackrain
what does the clutch fan pulley do?
what components should i replace first? radiator, pump, (something else)???
post #10 of 11 Old 06-30-2009, 07:48 PM
BrunoS
you have a worn out cooling fan clutch. $40, 30 minute fix. normal wear and tear item. your electric fan is working normally at on at 219'F and off at 207'F. it's a bit overworked if your main fan cltuch can't keep up, resulting in a "hot idle temp creep" at a red light.
you thermostat and temp sensor on the housing is correct. your dash gauge sensor near #6 cylinder is also good.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #11 of 11 Old 06-30-2009, 11:04 PM
MJR
MJR's Avatar
1988
You'd wire in a separate relay to the battery and have the switched side get power from the ignition switch so it shuts off. The switched power out of the relay will go to the green (I think that was the color) wire on the fan to turn it on.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
1996 Auxiliary Fan works with A/C but not Temp ba01raptoraz XJ Cherokee Technical Forum 9 07-12-2009 10:24 AM
1996 xj cooler temp runnin low XscottJ XJ Cherokee Technical Forum 4 12-03-2008 01:01 PM
TPS sensor, Coolant temp sensor, and 02 Sensor fail kadetklapp XJ Cherokee Technical Forum 2 09-07-2008 01:48 PM
General question about 1996 operating temp loanman XJ Cherokee Technical Forum 1 07-06-2008 01:27 PM
1996 coolant temp sensor question twinsdaddy24 XJ Cherokee Technical Forum 3 03-19-2008 09:43 PM
