Jeep won't start....really need help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Jeep won't start....really need help
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 10-03-2013, 10:00 AM   #1
smclaurin
I have a 2000 Jeep Cherokee Sport 4x4 with a 4.0 inline six. About 2 months ago it shut down on me while I was in line to pick up my kids from school. I had to pull it home because I couldn't get it to start. My husband and I have replaced the fuel pump because it would not come on. After putting the new one in, its still not coming on. Since then, we have replaced both the cam and crank sensors and not only is it not firing, but now all the gauges are not working, the fuel pump is still not coming on, and there is a no bus on the odometer. We've checked all the fuses and have replaced the fuel pump relay, but still nothing. I've read a few threads on here about this and we have done a few tests I've seen, but still nothing. Can anyone help lead us in a direction to find and fix the problem? We are both going crazy trying to fix it as it is our only vehicle at the moment. Any help with this will be greatly appreciated.
smclaurin is offline   Reply With Quote Quick reply to this message
Unread 10-03-2013, 12:17 PM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Random stalling, cranking over and not starting, some or/all gauges not working, and a No-Bus all point to a faulty Crankshaft Position Sensor or its wire harness.
Did you buy genuine Jeep sensors or cheap crappy "Lifetime Warranty parts" ? There is a difference.
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 10-03-2013, 02:45 PM   #3
smclaurin
We bought the sensors from Autozone, I read on another thread that Jeep parts are better but we couldn't afford it. We did test it and it is a good one, but I just replaced that sensor a year ago because it shut down on me 2 years ago. Am I going to continue having problems like this?
Unread 10-03-2013, 09:00 PM   #4
CJ7-Tim
CJ7-Tim's Avatar
Cheap crappy "Lifetime Warranty" parts are often out of specification, or even failed, right out of the box. Many times they have a short service life before they fail. Always buy top quality replacement parts and genuine Jeep sensors. Numerous threads detail long and frustrating searches for a phantom "problem" that ended up being cured with genuine Jeep repair parts.
Cheap parts are cheap for a reason.
Unread 10-04-2013, 08:22 AM   #5
smclaurin
We're still having trouble with the fuel pump not coming on, I don't have an owner's manual so its kinda hard to trace wires when you don't know what wires go to where. Do you have any diagrams or anything that could help us trace wires? We also need some help figuring out what to do about the gauges, none of them are working. Thanks in advance.
Unread 10-04-2013, 12:24 PM   #6
CJ7-Tim
CJ7-Tim's Avatar
Buy a Factory Service Manual. It contains diagnostic procedures, repair procedures, and complete wire diagrams. About $8 at http://www.pacificcoastmanuals.com/j...e_manuals.html
If the CPS is faulty, the fuel pump will prime for 2-5 seconds and then stay shut off until you fix the CPS issues. As a test, and only a test, you can jump the fuel pump relay.
Unread 10-04-2013, 05:26 PM   #7
smclaurin
How do I jump the fuel pump relay?
Unread 10-04-2013, 06:27 PM   #8
CJ7-Tim
CJ7-Tim's Avatar
See your Factory Service Manual wire diagrams. Use a small jumper wire from the 12 volts input in the relay socket to the relay output wire to fuel pump wire.
Unread 10-05-2013, 02:56 PM   #9
MaskedMallard
To test the fuel pump. Pull a known good working headlight from the vehicle. Disconnect the fuel pump wiring harness. Jumper the fuel pump wiring harness to the headlight. Attempt to start vehicle like you normally would. Does the headlight shine bright for about 2-5 seconds????
Make sure the battery is strong, don't assume. Put that battery on the trickle charger for 5 hours or so.
MaskedMallard is offline   Reply With Quote Quick reply to this message
Unread 10-06-2013, 04:41 PM   #10
Holder350
1995 XJ Cherokee
Check every single fuse in the PCM and in the passenger kick panel.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline   Reply With Quote Quick reply to this message
