jeep wont start, i think i need a CPS - JeepForum.com
post #1 of 11 Old 03-12-2005, 02:46 PM Thread Starter
Rock Kustoms
Rock Kustoms's Avatar
So i changed my starter because i blew the old one up, and it still doesnt start
my codes are 11, 42, 12, 25, 55 in that order
meaning
CPS
ASD
Battery disconnected
IAC
End
i disconnected the battery to change the starter, and popped the fuse for the ASD about 4 days ago, the IAC im not sure about, can that affect start up? no, right?
should i replace my CPS, or should i try and ohm it out, does anyone have the values?
Rock Kustoms is offline
post #2 of 11 Old 03-12-2005, 03:01 PM
ddoffroad
ddoffroad's Avatar
does it turn over at all or are you not getting anynmovement in the engine at all?
99 XJ - 4.0L HO, Rusty's K&N Intake, Rusty's 4.5" full suspension, 31x11.50 Swamper LTB's, 15x8 blk Daytona's, clear lenses, Warrior bumper w/ hooks
Down & Dirty Offroad:
My XJ site:
My Old XJ Site:
ddoffroad is offline
post #3 of 11 Old 03-12-2005, 03:08 PM
jandj
jandj's Avatar
does it crank? CPS will keep it from starting not cranking. Battery disc. means nothing since you disc your battery. If the IAC goes bad your enigne will start but not idle, just replaced mine by the way. To check the CPS you can backprobe the elec connection by the intake manifold. The book says to discconct and ohm b & C and it should be open (overload). I don't like that way. If you have a anolog meter you can backprobe the connector one wire will have about 5volts (power from computer) one will be a ground, and other will be return power to computer. With the meter set up for voltage probe the ground and the return wires and crank the motor over you should see the meter jump from o volts to 5 volts when the engine spins (you do need an anolog meter not a digital it happens to fast for a digital to read). If you have any other ?'s let me know...
sold my 96' XJ
Look'n to purchase now
jandj is offline
post #4 of 11 Old 03-12-2005, 03:37 PM Thread Starter
Rock Kustoms
cranks over fine
the b and c ohm trick doesnt work, im assuming A is the power, ill check that out b4 i go to get it
post #5 of 11 Old 03-12-2005, 04:42 PM
jandj
jandj's Avatar
what did you get when you check between b and c? should have been either overload (open) or approx. 0 ohms (closed).
sold my 96' XJ
jandj is offline
post #6 of 11 Old 03-12-2005, 08:50 PM
kcrunchone
try and use an analog meter it will give you more of an acurate... often you will get E or OE when checking between b and c.... using the analog will give you a better direction for trouble shooting...
krx
kcrunchone is offline
post #7 of 11 Old 03-13-2005, 07:15 AM Thread Starter
Rock Kustoms
damnit, i get 0 ohms between b and c.....
do i need to crank it over while checking?
post #8 of 11 Old 03-13-2005, 08:39 AM
CowboyPA
Before you go tossing a CPS at it, make sure your ASD Relay is good... Get a wiring diagram and just check that it's getting power ground and trigger, then make sure it is putting out.. These are known to fail and sometimes fail only to a point of passing reduced voltage. So just because it clicks dont mean nothing.. Been down this road and lost money (used to work flat rate) being fooled by a click..
I will try to remember how to make the tool, but I was shown a way of using a 9v battery and an LED to test the CPS... You disconnect the CPS from the harnass and feed 9v into one wire and then watch the LED flash as the motor turns (being cranked).. If I find the diagram I will post it here later today
99 XJ sport, Black, 4 door, 4 litre, 4wd
Black Jeep club member # 99
ASE Certified and professional Auto technician 12+ years
Every rose has it's Thorn, every XJ has it's leak, and every cowboy sings a sad sad song
CowboyPA is offline
post #9 of 11 Old 03-13-2005, 08:50 AM Thread Starter
Rock Kustoms
asd is good, swapped it w/ the AC clutch relay..... the fuse for the ASD is also good
post #10 of 11 Old 03-13-2005, 09:27 AM Thread Starter
Rock Kustoms
CPS replaced and she starts.....wont stay running at idle tho....IAC im assuming..... :-(
post #11 of 11 Old 03-13-2005, 12:39 PM
jandj
jandj's Avatar
yup, if it won't stay running @ idle check the IAC.
cowboypa, I like that little tool for checking the CPS I may have to make one thanks for the idea....
sold my 96' XJ
jandj is offline
jeep wont start right. girlinajeep XJ Cherokee Technical Forum 5 11-12-2009 07:36 PM
electric start prob. jeep wont start blackl4life XJ Cherokee Technical Forum 1 08-21-2009 09:56 AM
Angry Cherokee Wont Behave..start and die every 30 min! wont start then run 30 later! bcameron1974 XJ Cherokee Technical Forum 10 06-05-2009 02:22 PM
Please help, Jeep wont start!!! xstoyz XJ Cherokee Technical Forum 9 10-28-2004 03:11 PM
