Jeep won't start. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Jeep won't start.
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Jspec Suspension BLOW-OUT FEBRUARY ONLY!! HURRY UP!Income tax season is upon us. We got what u need
Unread 02-22-2011, 03:58 PM   #1
Bock
Daily driver won't start. Help please.
I went to start my jeep at about 4est today and it didn't start. The key had no resistance like it normally does right before it turns over. If you know what I mean. Like it'll go then get hard' then you push further to start it. Well my jeep doesnt do that. It goes right thru where that should be. It started just fine at about 1 when I got out of school. It's currently sitting in my garage. Had to push it in. Any suggestions/troubleshoots are welcome. I'm 16 and it's my daily driver. It is a 96 Cherokee country 4.0 high output.
Thanks in advance for any help guys.
96 XJ Country White AW4 4*4
If it breaks it just means upgrade
Bock is offline   Reply With Quote Quick reply to this message
Unread 02-22-2011, 05:03 PM   #2
tjwalker
It's the crank sensor!
tjwalker's Avatar
The ignition tumbler assembly is likely shot.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote Quick reply to this message
Unread 02-22-2011, 05:07 PM   #3
Bock
How hard/expensive is it to repair?
Unread 02-22-2011, 10:08 PM   #4
Bock
Any ideas???
Unread 02-22-2011, 10:57 PM   #5
1CVPaul
1994 XJ Cherokee
It's pretty straight forward - but you should have a repair manual on hand. Read through the procedure first before you start taking things apart. If your mechanically inclined then you should have no problem. I can't remember how much the ignition switch cost but that just means that it couldn't have cost to much.
1CVPaul is offline   Reply With Quote Quick reply to this message
problem , start , xj
