Jeep won't crank over. I've replaced everything. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Jeep won't crank over. I've replaced everything.
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 05-04-2012, 11:12 PM   #1
PyroPhan
1994 XJ Cherokee
So here's the deal. I've got a '94 Cherokee Country with the 4.0 motor. Most everything is stock. I've been running into a problem every now and again in which the Jeep won't turn over. It only happens once in a while. It's frustrating because it renders the truck completely inoperable. I turn the key and nothing. Not a click or anything. All the lights come on, radio turns on. I've got a strong charge from the battery. Ive already bypassed the NSS so I'm highly positive that the NSS isnt to blame. Sometimes it flat out wont crank no matter how long i hold the key in the start position, and sometimes i'll hold the key in the start position and it will finally crank after 5-10 seconds of holding it. I've replaced the battery with an Optima Yellow Top, so we know it's not a battery issue. I've replaced the starter, twice. So we can rule that out. I've switched out the Starter relay with the AC relay and had the same results... I have no more ideas, please throw me a bone here.
PyroPhan is offline   Reply With Quote Quick reply to this message
Unread 05-04-2012, 11:18 PM   #2
RockHard07
check out the ignition switch. i dont have alot of experience with cherokees, but i replace ignition switchs on GMs all the time and they do the same thing when they crap out
good luck
cross threading is as good as locktite!
RockHard07 is offline   Reply With Quote Quick reply to this message
Unread 05-04-2012, 11:21 PM   #3
PyroPhan
1994 XJ Cherokee
I'm pretty sure it isn't the Ign Switch because all of my dash gauges and everything act appropriately when I have it in the 'start' position. Thanks for the idea though, I'll look into it. Anyone else have any more ideas?
Unread 05-04-2012, 11:26 PM   #4
jeepjunkymike
run a wire directly to the solenoid on the starter and see if it starts that way,,that will narrow down the hunt
lift it,,,,fat girls cant jump
jeepjunkymike is offline   Reply With Quote Quick reply to this message
Unread 05-04-2012, 11:29 PM   #5
whitexj98
That will just verify the starter is good, sounds like the problem is in the circuit to the solenoid.
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline   Reply With Quote Quick reply to this message
Unread 05-04-2012, 11:29 PM   #6
PyroPhan
1994 XJ Cherokee
I've jumped the starter by bridging the terminals with a screwdriver, and it starts. With this being the third starter in the truck, I'm willing to believe the starter isn't the issue.
Unread 05-04-2012, 11:32 PM   #7
whitexj98
Your positive the NSS is jumped "good", This sounds like a classic NSS. How exactley did you jump it?
Unread 05-05-2012, 02:46 AM   #8
PyroPhan
1994 XJ Cherokee
Paper clip snugly fit into the terminals, and secured and insulated with electrical tape. I'm going to see about rebuilding it tomorrow and see if that changes anything. The jump has been working adequately for the past 3 years. I'll check it and get back to you all.
Unread 05-05-2012, 06:05 AM   #9
xjfever
xjfever's Avatar
1995 XJ Cherokee
I am gonna guess it is the ignition switch. I had the same issue a few years ago and the switch fixed it for me.
xjfever is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 06:05 AM   #10
caged
1990 XJ Cherokee
is it the same paperclip for the last 3 years?
maybe check to see if it's getting proper connection. possibly replace with a larger paperclip.
or just install a push button starter wired to the solenoid...
caged is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 07:20 AM   #11
theshaolin
My vote is ground cable corrosion or the like.
1996 Cherokee Sport - 4x4 4.0L - Wheeling Project
1986 Mazda RX-7 Turbo - 400RWP project - 2000 Saturn SC1 - Turbo RWD project
1996 Suzuki Bandit 600 - Frame up restore project - Too Many Projects!!
1991 Chevrolet K1500 - 4x4 5.7L 5spd - For Sale (Cheap!)
theshaolin is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 07:28 AM   #12
Trons
That's what I was thinking. I would also like to say that I think this is the first electrical problem thread I've seen that didn't have 100 people saying to remove, clean and replace all the ground connections in the engine bay.
'03 TJ Rubicon
'91 Cherokee Laredo, Stock - Sold
'98 XJ - burned :(
Trons is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 05:41 PM   #13
BlueRidgeMark
1994 XJ Cherokee
Replace-this-replace-that-replace-that-again-replace-something-else is a great way to be broke and frustrated.
I suggest jumping the ignition switch. Stop messing with the starter - you've already proven that's not the problem.
Cleaning grounds isn't a bad idea, but my money is on the ignition switch.
Troubleshoot, don't just throw parts at it.
BlueRidgeMark is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 06:11 PM   #14
PyroPhan
1994 XJ Cherokee
Troubleshoot by throwing parts at it?
Unread 05-06-2012, 09:56 AM   #15
Saudade
1988 XJ Cherokee
There is a dedicated contact in the ign switch to feed the starter relay. Pull the starter relay in the PDC and use a voltmeter in the socket on Pin 86. Turn the key to start. You should get 12V. If not, the feed from the switch is bad. Pin 85 should read ground with your bypassed NSS.
Carefully, apply 12V to Pin 87. This feeds the starter solenoid and see if it cranks.
Saudade is offline   Reply With Quote Quick reply to this message
no start , start problems , starter , starter issue , starting problem
