Jeep won't start. - JeepForum.com
post #1 of 5 Old 02-22-2011, 03:58 PM Thread Starter
Bock
Daily driver won't start. Help please.
I went to start my jeep at about 4est today and it didn't start. The key had no resistance like it normally does right before it turns over. If you know what I mean. Like it'll go then get hard' then you push further to start it. Well my jeep doesnt do that. It goes right thru where that should be. It started just fine at about 1 when I got out of school. It's currently sitting in my garage. Had to push it in. Any suggestions/troubleshoots are welcome. I'm 16 and it's my daily driver. It is a 96 Cherokee country 4.0 high output.
Thanks in advance for any help guys.
96 XJ Country White AW4 4*4
If it breaks it just means upgrade
Bock is offline
post #2 of 5 Old 02-22-2011, 05:03 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
The ignition tumbler assembly is likely shot.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 5 Old 02-22-2011, 05:07 PM Thread Starter
Bock
How hard/expensive is it to repair?
Bock is offline
post #4 of 5 Old 02-22-2011, 10:08 PM Thread Starter
Bock
Any ideas???
Bock is offline
post #5 of 5 Old 02-22-2011, 10:57 PM
1CVPaul
1994 XJ Cherokee
It's pretty straight forward - but you should have a repair manual on hand. Read through the procedure first before you start taking things apart. If your mechanically inclined then you should have no problem. I can't remember how much the ignition switch cost but that just means that it couldn't have cost to much.
1CVPaul is offline
problem , start , xj
Help! Clueless Female with Jeep Cherokee! Jeep won't start after lots of repairs! TRA1216 XJ Cherokee Technical Forum 33 10-28-2012 03:28 PM
need immediate help, jeep won't start!!! cademan04 XJ Cherokee Technical Forum 2 08-22-2009 01:24 PM
electric start prob. jeep wont start blackl4life XJ Cherokee Technical Forum 1 08-21-2009 09:56 AM
Jeep will not start? bv8 XJ Cherokee Technical Forum 20 08-08-2006 10:53 AM
Jeep wouldn't start, then it started, now it won't start... Jeep84CJ7 XJ Cherokee Technical Forum 16 09-21-2005 07:41 PM
