Jeep surges while driving/ wont idle properly - JeepForum.com
post #1 of 24 Old 01-26-2008, 10:25 PM Thread Starter
Gsmyth75
1992 XJ Cherokee
I recently had yet another freeze plug come out on me, and after reassembling my intake and exhaust manifolds my jeep just seems to not want to idle, and when i get it going down a road it will feel like i let off the gas and then surge forward as if im bliping the throttle, when my foot doesnt move. I thought maybe i had a leak or something in my intake manifold but i took it all apart again and reassembled it all only to still have this problem, I know all the sensors are reconnected. No check engine or anything. My only guess is bad injector o-rings which looked torn up and im going to replace tomorrow, anyone have any other guesses as to why it is running funky?
1992 Cherokee Laredo 4.0 L6, Aw4, Dana 30/35, Np242, 201k
Crower p/n 44243 Camshaft, Camsaver High Oiler Lifters, He Pistons .030 Over, Decked Block and MIlled Cylinder Head. Melling High Volume Oil Pump
Flowmaster Super 40/ Cat and Tailpipe Delete, Apn Header, Homebrew Bored Throttle Body, Rustys Cold Air Intake with Spacer
Gsmyth75 is offline
post #2 of 24 Old 01-26-2008, 10:28 PM
SmrtJustin
SmrtJustin's Avatar
This all happens when you're foot is off the gas, correct? If so, I would guess it's your Idle Air Control (IAC).
1999 Cherokee Classic
Deep Amethyst
60,000 miles
Mods:
Dynomax Cat-back
OME CS035RA Heavy Load Rear Leafs (~3.25")
RE 1334 Front Spacers (~2.5")
P.O.R.C. HD SYE
30x9.5 General Grabber AT2s
B&M SuperCooler 70255 and Temp Guage
SmrtJustin is offline
post #3 of 24 Old 01-26-2008, 11:05 PM
mickdawg777
1995 XJ Cherokee
Fuel filter been replaced lately? Sounds like a TPS fluctuation in voltage levels. Rough idle is caused by sticky IAC's. IAC's do not have anything to do with hesitation/surging at a given throttle position.
Check your plugs, plug wires, cap, and rotor. If the cap is black with carbon on the contacts, chuck it and get new rotor and cap. Same for the plugs and wires.
Chris a.k.a. "Mickey"
I always manage to buy absolute junk and putting tons of $$$ in it. No such thing as a good deal.
mickdawg777 is offline
post #4 of 24 Old 01-26-2008, 11:38 PM
SmrtJustin
SmrtJustin's Avatar
Idle problems can be caused by the IAC. But after reading your post multiple times, it sounds more like you also have problems while driving, that sounds more like a TPS.
Deep Amethyst
60,000 miles
Mods:
Dynomax Cat-back
P.O.R.C. HD SYE
post #5 of 24 Old 01-26-2008, 11:57 PM Thread Starter
Gsmyth75
1992 XJ Cherokee
It happens while driving (on the gas) and while just sitting at an idle. I dont think it would be an ignition related thing cause this only happened after I re did my manifolds. And the fuel filter was replaced a short while ago. Im going to try replacing fuel injector o-rings tomorrow, spraying carb cleaner around the intake gasket to see if theres a difference, and try cleaning out/ testing my iac and tps, and resetting the computer. I did take off the two connectors on the throttle body while doing the freeze plugs but i put them back on fine, how easily do they break? could I have damaged it by disconnecting it twice? If this helps while driving it and it started surging I floored it and it didnt kick down to 2nd like it would normally, it only kicked down to 3rd, so I'm leaning more to the tps/iac not working properly.. Thanks for the quick responses this late at night!
Gsmyth75 is offline
post #6 of 24 Old 01-27-2008, 07:21 AM
MattS
My 99 will do this kind of thing, mostly when the engine is warm. I've replaced TPS, IAC, fuel filter, plugs, caps, and wires. I'm at a loss so post what you find out.
99 Sport - RED
3" Skyjacker AAL kit
31 x 10.5's
JCR Offroad Stage 3 Front Bumper
Custom 4x4 rear rocker guards
MattS is offline
post #7 of 24 Old 01-27-2008, 07:40 AM
HighCountry
The vacuum line to the Fuel Pressure Regulator is OK?
Bruce
HighCountry is offline
post #8 of 24 Old 01-28-2008, 07:48 AM Thread Starter
Gsmyth75
1992 XJ Cherokee
Fixed
Bruce
Thanks alot man, I had checked the vacuum line, but not the connectors to the line. One of them was cracked beyond belief. A trip to advanced auto to get a new connector fixed all of my weird idle problems. So thanks for saying that which made me double check it. Also it's weird what you find out while tearing stuff apart, now I have a couple more projects.
Gsmyth75 is offline
post #9 of 24 Old 01-28-2008, 10:58 AM
collkid
And where is that fuel pressure regulator? anyone?
2000 Jeep Cherokee. 4.5', Long arms, Bumpers front and rear, Winch.
1992 Toyota Paseo DD 35+ MPG
Colorado Member #89
collkid is offline
post #10 of 24 Old 01-28-2008, 09:49 PM Thread Starter
Gsmyth75
1992 XJ Cherokee
On my `92 look for a vacuum line going from the intake manifold to the fuel rail (with the injectors on it), and it's where the vacuum line connects.
Gsmyth75 is offline
post #11 of 24 Old 01-29-2008, 06:04 AM
SmrtJustin
SmrtJustin's Avatar
The fuel pressure regulator is in the tank.
Deep Amethyst
60,000 miles
Mods:
Dynomax Cat-back
P.O.R.C. HD SYE
post #12 of 24 Old 01-29-2008, 06:32 AM Thread Starter
Gsmyth75
1992 XJ Cherokee
Maybe on your `99 but on my `92 i'm pretty sure it's on the fuel rail.
Gsmyth75 is offline
post #13 of 24 Old 02-05-2008, 08:33 PM
SmrtJustin
SmrtJustin's Avatar
You are correct. I apologize for that, somehow I got mixed up and thought you had a newer XJ.
Deep Amethyst
60,000 miles
Mods:
Dynomax Cat-back
P.O.R.C. HD SYE
post #14 of 24 Old 04-28-2008, 11:09 AM
firerescue251
I am having the same problem as the first post on this thread. I have replaced o2 sensors, IAC, tested the tps and it came back with .91 ohms at a closed throttle and 4. something at WOT. Done a vacuum test which was inconclusive due to the fact that it didn't exibit the problem, of course, when i did the vacuum check. I'm running out of choices.....
firerescue251 is offline
post #15 of 24 Old 04-29-2008, 04:09 PM
jcrowley
jcrowley's Avatar
1997 XJ Cherokee
new plugs, wires, rotor button dist cap, new tps...no luck. i've done fuel pressure test...it's solid at 49 or so psi. i'm at my whits end with this thing. i've haven't done a fuel filter change in awhile, but i'm hestitant to do that just yet not really knowing what the problem is.
97 Cherokee Sport
jcrowley is offline
Idle surges when it rains! (searched) limited XJ Cherokee Technical Forum 9 11-07-2009 01:50 PM
Thermostat wont sit properly on head! tmcarr XJ Cherokee Technical Forum 6 09-01-2009 03:00 PM
Power Door Lock wont work properly joefish76 XJ Cherokee Technical Forum 5 08-12-2009 04:59 PM
Driving lights wont shut off!! xjman4life XJ Cherokee Technical Forum 3 02-09-2007 06:34 AM
Engine surges just off idle? sirhk100 XJ Cherokee Technical Forum 0 05-23-2005 08:31 AM
